0 Members and 46 Guests are viewing this topic.
T-1000
Quote from: baroutologos on August 25, 2013, 02:58:21 PM
ps: too many assumptions on the row
Yes, it is too much assumptions and to solve them you need make test case by own hands. Then you can check if there is neutron emission and do other measurements.
Quote from: TheCell on August 25, 2013, 03:48:35 PM
@T-1000
I have a few understanding questions about this experiment of Ruslan.
Based on his YT video, I have drawn a schematic .
Does it represent the experiment in his YT video?
http://www.youtube.com/watch?v=xuKiLjv0UqY
With a relay I pulse this one coil and can vary the space mark ratio
of the applied pulse. A compass nearby the coil deflects only slightly,
not as in his film.
The "cold" end of flyback is in the air, the "hot" goes to the grounding over spark gap there.
Again, this is same approach as I showed in previous Russian video ;)
The only drawback of my flyback transformer (without diodes) could be
that one connection of the HV winding has a strong capacitive effect on
the other connections of the flyback, because you don't need to connect this
lead that is normally connected to ground. But there is no galvanic connection
of the HV winding to other connections of the flyback. If there is an arcing
in the transformer (although I don't here one) it could provide a connection
during operation.But how could I know...
Therefore , if there is a strong impulse , that should proceed trough the
thick copper wire to the ground , this capacitive effect could hinder it from
doing so.
BTW :
If you look at Fabrice Andres flyback : he uses also one like in the video of
Ruslan . The HV winding is completely the only winding in this plastic case.
Is this a must?
You see even these simple setups can't be done, there is no sense to proceed
with the more complicated. There should be an entry point for getting this effect.
He is not using a ferrite core, so NMR with ferrite can be excluded as an effect.
So what remains ? NMR with copper, an electron avalanche effect similar to radio
tubes, which tiger showed , using radio tubes not using the heating filament.
There is capacitive loop in any case so the flyback makes good insulation as possible to overcome this. But when 1 wire from secondary goes to grounding and second is in air it is like transmitter with antenna situation. Just antenna goes into ground and its field is used in transformer over 90 degrees(A spinning field is influencing transformer while B field goes along wire). And if this intrigued you my advice is just to repeat this experiment.
To me it is NMR condition when you have magnetizing current on transformer primary and resonant field on 90 degrees from spark gap in wire going inside of tube - http://www.youtube.com/watch?v=1OrPCNVSA4o
Hoppy
Quote from: NickZ on August 25, 2013, 02:25:35 PM
Or, you can connect a couple of transformers together yourself, and say a few magic words. See if that works...
You'll need a magician to do that. Ask TK to wave his wand. ;D
magpwr
Hi everyone,
I have found a video on Tariel Kapanadze -From video looks like a interested investor or observer-unconfirmed.
Take a look at video you will notice basic test done like "test pen" on garden tap and etc.
Please hear the sound of the spark do hear the frequency of sparking which likely this is used to "excite the toroid core in series via a thick straight cable in it"(maybe) at 8:40min onwards.
This is meant for those whom may not have seen this video.
http://www.youtube.com/watch?v=8CSkzA9oPSE
baroutologos
Quote from: magpwr on August 25, 2013, 09:35:33 PM
Its a nice morning over here, i drink coffee and i feel like i want to comment something.. :)
Assuming you have a working device per Kapanadze (no such luck) and a further assumption that it works on NMR, then if you employ a Toroidal or cylindrical coil (as we have seen) having the magnetizing windings wound around the cylinder (inverter or not) then the Oscillating magnetic field of high frequency (hence RF) for achieving the procession must go vertical to it. Vertical means on the other magnetization vector, i.e. wounding the coil from top to bottom of the cylinder (composed of many toroids) each turn passing inside the hole.
Only one cable inside the hole means 1 turn. From my experience, windings like that have much larger inductance per turn (as its natural) than the around the cylinder windings.
e.g  for a cylinder made of 20 x 35mm diammeter soviet 2000 HF permeatbility toroids, some 10-15 turns of wire wound around the cylinder equals in inductance to one wire passing through.
