0 Members and 44 Guests are viewing this topic.
Jack Noskills
Quote from: Hoppy on August 26, 2013, 04:19:04 AM
At what point - number of turns - in the video did you doze off.  ;D
You can skip to the end, around 2 hours 25 minutes and see the magic happen. There is download link where you can get the parts list, schema if you still need it. I watched just the end and downloaded specs.
C'mon, this is shown from the first drilling of a hole to big LCD display finally connected at output and gents, 'we have power!'.
If you are a builder, this is where to start. No semiconductors, only caps and coils. Someone should now save this video before it is removed.
Hoppy
Quote from: Jack Noskills on August 26, 2013, 06:39:23 AM
I did when I eventually woke up when the video had finished and I skipped back and eyeballed a big lamp array on a board propped up against the table with wires behind it.  ::)
baroutologos
Quote from: magpwr on August 26, 2013, 06:18:41 AM
Hi Hoppy,baroutologos and everyone,
[size=78%] [/size]
Hey magpwr,
I see you start experimenting heavily on many different concepts at once, making custom magnet orders etc. Seems you can spend few or more bucks for your fun or research.
Concerning the impedance mismatch is a serious issue on mechanical or electrical circuits. If not taken into consideration, power transfer will be poor.
Concerning your "no input, OMG i have power out video", my piece of advice is to skip using DC ammeters of that kind (especially if mismatched) or even DMM's ammeter. Just put in shunt to input a known resistor e.g. 1 ohm 5watts or 0.1 ohm 5watts and have the DMM measure the voltage. Apply ohm's law and estimate amperage.
So simple and accurate even down to few mA scale.
Hoppy
Quote from: baroutologos on August 26, 2013, 10:21:58 AM
Hey magpwr,
Good advice!  :)
magpwr
Hey magpwr,
hi baroutologos,
Base on the youtube link which i have posted about 4hours ago related to 12v 0 amp input 12 watt output.After watching that video for the 4th time to catch the fine details. :)
At the last part you  will notice he excluded the CAR Battery away and "it was running on capacitor" the output was 12watt bulbs for 1 or 2min after which he used finger to touch bulb to maintain similar brightness.This he called it squeezing more juice for fun.
He have done alot of serious experiment especially with HV.There is a interesting video of his which he use capacitors in parallel with  "PWM500 Resonant plasma driver " for all his experiment.There is a site selling this device with plans as well not easy to locate site at first.Upon connecting capacitor to input of PWM500 the mains Amp reading drops.Maybe he didn't know that was called "powerfactor correction". :D
To save time this is the site selling that Plasma driver which he is using.The price is ridiculously high for assembled unit base on the provided free plans in the same site.
http://www.amazing1.com/hv-hf-power-supplies.html
