0 Members and 59 Guests are viewing this topic.
magpwr
Quote from: ariovaldo on August 26, 2013, 04:23:36 PM
Good afternoon Hoopy....
Yesterday I tried some setups that I planned at the begging of the week,  using MOT with 3 turns as output, connected to other one with 10 turns as input and 120 turns (original from the MOP) output. I used thyristor, diode, capacitor in every conditions that I could do and I just noticed one anomaly that I will purchase some test instrument to confirm that. This "anomaly" was some gain in light intensity associated to current decrease, using a thicker cable as output. (I was using 10 turns of 8 AWG and start to use 6 turns of 8 AWG plus to 2 turns 1/0)
I didn't give up and I will be testing some more points using transformers, thicker wire connected to the grid / inverter and most important, try to create a resonance.
Take a look in this attachment: it is not OU.
It is a simple movie where I used old TV yoke, feed by 12 volts AC( square wave) with a variable frequency. There are 2 wingdings  Primary with 17 turns, 10 AWG wire, secondary with 42 turns of 14 AWG. The secondary was wound in 1 ½ inches aluminum tube with a slot and the primary was wound in the middle of secondary.
What is important is to use the capacitor to create a resonance in the secondary, so the light will be in the maximum intensity.
http://www.youtube.com/watch?feature=player_detailpage&v=Dl6bd-w1VIE
Hi ariovaldo,
It's a good start with the yoke experiment.I also liked the sountrack kinda reminded me of "mission possible" movie soundtrack. :D
This video i have attached might give you some insight related to yoke resonance which might help you in your experiment.
Attached link- Pulsing a Yoke Coil 6 -Please checkout other yoke  related video from this youtube user.He did mentioned T-1000 in video.Interesting.
http://www.youtube.com/watch?v=FR5YDawEBu8
bringdownthezog
Quote from: Hoppy on August 27, 2013, 06:12:35 AM
If you are referring to that poor quality video showing a small bulb illuminated off what looks like a couple of AA batteries, I think from the rest of that rambling post that this is supposed to represent a resonant transformer. If so, then yes, this is what TK is probably doing on a much bigger scale but what represents the AA battery energy source in TK's case? That's the question that needs answering because a resonant transformer needs power to make it resonate and more to the point a continuous supply to maintain resonance.  :)
Hoppy you dunce ! The video you are referring was from a message I was replying to.    :D  :D  :D
Hoppy
Quote from: bringdownthezog on August 27, 2013, 07:04:30 AM
Then do as I requested and make make yourself understood instead of just smiling like a 'Cheshire Cat'.  ::)
bringdownthezog
Quote from: Hoppy on August 27, 2013, 07:13:05 AM
Then do as I requested and make make yourself understood.  ::)
Really ?  You can't differentiate between a post and a reply quoted in a post ? Tsk tsk.
