0 Members and 382 Guests are viewing this topic.
bringdownthezog
Quote from: Hoppy on August 27, 2013, 08:45:35 AM
Why would you think I would want to do that.  :o
Try answering my original question.
I'll answer your question first by saying that I can see no evidence for or against it.
Here I was thinking you were going to enthrall us with your intelligence ! Try reading first. It will cure all your inane questions.
REMINDER !! Read from the post I gave you. Not the quoted text  !!!
the attachment named '26159553-Free-Energy-estress.pdf' !!!!
Hoppy
Quote from: bringdownthezog on August 27, 2013, 09:00:14 AM
Thanks, I had already found the document but thanks for holding my hand along the way whilst we were playing games. :-[
Interesting as it is, now that I have read it carefully, I need to check my intelligence level, as I cannot understand how it could possibly be the modus-operandi for TK's high powered solid state devices!
ariovaldo
Quote from: magpwr on August 27, 2013, 06:20:40 AM
Hi ariovaldo,
It's a good start with the yoke experiment.I also liked the sountrack kinda reminded me of "mission possible" movie soundtrack. :D
This video i have attached might give you some insight related to yoke resonance which might help you in your experiment.
Attached link- Pulsing a Yoke Coil 6 -Please checkout other yoke  related video from this youtube user.He did mentioned T-1000 in video.Interesting.
http://www.youtube.com/watch?v=FR5YDawEBu8
[/font]
Thanks.
I had tried it before but I still think to have one more trial using this conception..
Ari
bringdownthezog
Quote from: Hoppy on August 27, 2013, 10:14:46 AM
Intelligence ? All I've seen is the innuendo !!!
magpwr
Hi everyone,
Finally got my 4x 40KV 1A diodes and few 50KV 500pf and 50KV 2N2 caps today.
This is got to be the biggest diode ever used for ou experiment. :D
This will be used in Lithuania device as attached.
Previously i have highlighted to T-1000 that the diode used in their experiment was underrated at 15KV base on observed sparks in video.
Another test i have done as attached base on my rather recent experiment revealed that i was able to light 5watt bulb as seen in attached photo via spark from my HV transformer using around 4watt of power with 12volt battery input.Of course this is after tuning the frequency and pwm using one IC:SG3525 to suit hv transformer.After that experiment using 4watt of power.I merely made simple modification by moving 3300uf capacitor (+) to center tap of my self made 5-0-5(turns) winding (-) of capacitor is connected to both mosfet source using shortest possible wiring with some allowance.The efficiency was improved by 1 watt less at around 3watt to light that same bulb now.
Photo was not attached.
In the Lithuania experiment i understand higher power in watt around 34watt or more was used by mains to get hv transformer sparks to power the device.
It's nearly 1 hr to midnight over here.
Base on attachment SR193-
I will be emulating the ic:4069 /  K561ӅH2  in a virtual electronic environment just to see what kind of frequency is being generated eg:50HZ or close and waveform if it will be rather nice sine wave at the output. ;)
Other portion of SR193 needs to be physically constructed pending delivery on some key items.
