Zeitmaschine
Quote from: v8karlo on August 30, 2013, 07:03:42 PM
In this patent LIETUNOV VOLODYMYR states that closest to this invention is Tariel Kapanadze's WO2008103129 patent.
Nice and interesting!! So now we have one more free energy patent but still no free energy. :D >:(
Since the patent states that coil 1c can have only one single winding, to me 1c and 2a looks like a Tesla coil or a simple high voltage transformer like this one.
The (single) winding 1c is driven by the generator 1b and the patent states that »Especially important is the waveform (slope) of electromagnetic signal that creates resonance of the surrounding space.«
Hmmm ... the waveform (slope) of my high voltage generator is a square-wave voltage (like depicted in the patent drawing), otherwise I can't get any high voltage out of it. And since I do not have anything to connect to the secondary coil (except ground and/or a spark gap) my secondary high voltage coil is connected to nothing, as also stated in this patent. So what? Assumed that my (or every) high voltage coil is surrounded by free energy (resonance of space?), it seems all that is missing here is 3a, namely the energy collection module for the free energy. What could that be?
The fundamental problem is this: Are all these patents and devices based on one and the same physical principle? If so, then why is (here) no one able to combine all this knowledge to build a working device? Or are all these patents and devices based on different physical principles? Then why can no one (here) hit at least one of these multiple principles in order to build a working device? Very strange indeed. And if all these devices are fakes presented in the course of a century, then this would make it even all the more strange.
magpwr
Quote from: Zeitmaschine on August 31, 2013, 09:30:35 AM
Hi Zeitmaschine,
I have analyse the circuit.This circuit only show the transmitter stage or hv driver to mini hv transformer.
But the receiver circuit is missing from picture.Are you able to obtain that receiver circuit picture or receiver schematic for 3a 3b 3c.
Very neat circuit on a breadboard indeed.
There is no possibility of ou since there is "no loop back shown" only the step down transformer is supplying power to circuit.
This reminded me of some video i've seen in youtube where power is transmitted remotely around 1 or 2 meters away where both transmitter and receiver winding is done on plastic bottle.
Same concept.
Zeitmaschine
Quote from: magpwr on August 31, 2013, 09:52:48 AM
Since the output of the energy receiver (in TK case) is 50Hz then the task would be to convert the static energy field surrounding the high voltage coil into 50Hz current. Hence, what if one coil of a 50Hz transformer is connected to 50Hz input (from inverter), a second coil is connected to the load and a third coil is connected to high voltage (one end only), maybe just in proximity of the static high voltage field without galvanic connection or sparking (like shown in the patent)?
Actually I have never tried this yet in order to extend the lifetime of my equipment. ::)
But at least we know there is a high voltage generator in TK's tin can and if there is also a 50Hz transformer (or coil) in that tin can then surely both parts are in close proximity to each other (inclusive shielding of the static field by means of the tin can).
00
Quote from: Shokac on August 31, 2013, 02:21:04 AM
DonL
This is not solution.
I try all sorts of combinations, but nothing happens.
This loop coil is DRIVER for something.
Read patent:
The above objective and other objectives are achieved in the present invention by a device comprising at least three sets of at least one electromagnetic field generating device (without a core or with at least one core) powered by an electrical power source, having their cores or any extension of them, with their coils or sets of coils, wound on at least one common conductive member in a closed circuit which is polarised by a voltage source, and these sets of electromagnetic field generating devices are arranged with their poles in confrontation, to promote the interaction of electromagnetic fields, and, preferably, positioned between two hollow metallic hemispheres, in order to focus and enhance their electromagnetic fields - these interactions cause a new technical effect - the emergence of an electric current which keeps flowing in a closed loop, with or without voltage being applied to that closed loop, current which is capable of powering external loads - even if no load is attached to it.
