0 Members and 437 Guests are viewing this topic.
MenofFather
Такая предположение. Что может быть два трансформатора. Когда вторичная обмотка закорочена на другом трансформаторе, то оно получаеться не как закороченно, а как передающая на другой трансформатор и тогда потребление, если качественно зделать не будет 30 ампер, а около 10-100 милиампер и 220 вольт к примеру. Поэтому там и рисуют по два трансформатора. Либо может вторичная обмотка должна быть отдалена от первичной и крепко закороченна из толстого провода.
Zeitmaschine
Quote from: Hoppy on August 31, 2013, 04:25:23 AM
Here is a revised version of my schematic showing the possible interconnections for TK's Tin Box device. A.King21 to note that a 'stick man' is not required for this device.  ;)
Almost forgot: What do we have when the black transformer on the chair is not connected on both sides (primary and secondary) like shown in the video prior to 19:00, but the device is working nevertheless (the lamps are lit)?
Maybe a second hidden wire is needed. But why take the risk of TWO hidden LIVE wires?
forest
You will soon find very strange thing.... ::)  Every device from 1890 up to now based on the same concept ???? Sure, why not... however the most interesting is the close relationship of most devices embodiments... That's even better because we can trace the working principle back to the old age when there was no electricity ! Back in time to 1840 and probably even more ,but archives contain no so many such old documents. It's important to eliminate wrong statements, easily made in our polluted envinroment.
Zeitmaschine
Quote from: forest on August 31, 2013, 04:32:10 PM
Maybe two concepts. Because electrons can be influenced (attracted) either by a magnetic field or by an electrostatic field (or both). Perhaps that's what's creating the confusion. Electricity is a very strange thing indeed.
Hoppy
Quote from: Zeitmaschine on August 31, 2013, 01:35:44 PM
As I said earlier, prior to 19:00 it runs on the battery and inverter. Look closely and you will see wires clamped to the battery posts and running into the inverter.In fact up to 22:36 the battery is connected, after which the all wires are removed from the battery when it is pushed aside. The alternative supply from the transformer has already been connected prior to this by his assistant at 19:00.
