0 Members and 346 Guests are viewing this topic.
ariovaldo
Quote from: 00 on August 31, 2013, 06:26:13 PM
the secret of kapanadze
is SRD
Step recovery DIODE! example mpn 3401
a frequency multiplier using a diode that has a long Carrier Lifetime and short Transition Time. Some diodes that exhibit these qualities are Step Recovery Diodes,
Varactor Diodes,
PIN Diodes.
SRD, Snap, and PIN Diodes they all mean the same thing.
A step recovery diode (SRD) is a semiconductor junction diode having the ability to generate extremely short pulses. It is also called snap-off diode or charge-storage diode or memory varactor, and has a variety of uses in microwave electronics as pulse generator or parametric amplifier.
When diodes switch from forward conduction to reverse cut-off, a reverse current flows briefly as stored charge is removed. It is the abruptness with which this reverse current ceases which characterises the step recovery diode.
kapanadze circuit  elements
first filter first frequency adjustor
second filter second frequency adjustor
00
00, Hoppy..
Ok, I do think we got something here....
If we use a transformer like in the Barbosa patent, having the secondary (thicker wire) feeding a special transformer ( primary) and this primary connected in a high voltage and high frequency circuit. This primary will be the cathode, like in microwave circuit.
The " special" transformer got have an anode, that can be aluminum  tube grounded and between the " anode and the cathode" we will have the pickup coil.
Check this circuit and imagine instead a magnetron, we have the " special" transformer.http://www.google.com/search?q=microwave+circuits&client=safari&hl=en&source=lnms&tbm=isch&sa=X&ei=EnsiUrPUEeKV2QWXi4CAAg&ved=0CAkQ_AUoAA&biw=1024&bih=644#biv=i%7C45%3Bd%7CaQ-pjIz2kozf-M%3A
Let me know what you guys think...I will test this, changing the frequency...
Hoppy
Quote from: ariovaldo on August 31, 2013, 11:04:14 PM
00, Hoppy..
Are you referring to the magnetron circuit below? If possible, please provide circuit diagram of what you are proposing for clarity.
Zeitmaschine
Quote from: v8karlo on August 30, 2013, 07:03:42 PM
Quote from text of WO2013114285 LIETUNOV VOLODYMYR patent:
"The closest patent is the International Patent
      Application No. WO2008103129, (Tariel Kapanadze's patent) published on August 28, 2008."
"This application describes an energy-independent system that generates energy surplus, part of which is used to sustain operation of system itself and the remaining part is sent to the power grid."
The Lietunov patent describes the Kapanadze device as having an antenna which produces ozone (point 6 refers to point 5). That is something new to me. The Kapanadze patent does neither mention an antenna nor does it mention the production of ozone (it does not even mention high voltage). Also I cannot see any antenna or any hint of ozone production in any of the Kapanadze videos. So how does Lietunov got the idea of an ozone producing antenna on the Kapanadze device? Is Lietunov close to Kapanadze so he knows the Kapanadze secret (and improved it a little bit)?
a.king21
Lietunov patent. Thanks Zeit. That's my homework for the next week then. Good find.
ariovaldo
Quote from: Hoppy on September 01, 2013, 05:55:02 AM
Yes. Today I'm working in the " honey to do list" and tomorrow I'll test it.
