0 Members and 51 Guests are viewing this topic.
Zeitmaschine
The primary signal generator unit the Lietunov patent is talking about -I guess- is the high voltage generator (producing ozone), the secondary signal generator unit then is the 50Hz inverter. Since I can't spot any high voltage generator in the Stepanov transformer setup, I would say, there are basically two different principles to run such devices, one principle works with an electrostatic field the other works with an electromagnetic field in order to influence the electrons.
Therefore time for some (weird) theories about moving electrons. :D
The primary coil of a transformer is connected to mains. The primary coil generates a magnetic field in the core of that transformer, this magnetic field then generates a voltage in the secondary coil. That means the magnetic field moves the electrons in the wire of the secondary coil back and forth, therefore an AC voltage appears across the two endings of the secondary coil. So far so simple, but:
1) The lamp is lit when connected directly to the secondary coil.
2) The lamp is also lit when connected to the secondary coil via two (very) long wires. That means the electrons in these wires are moved back and forth (negative end is surplus of electrons, positive end is lack of electrons) although these wires are not directly influenced by the magnetic field of the transformer (even when the lamp is not connected).
3) One of the wires is connected to a (very) large massive copper ball (envision a diameter of a few meters). The lamp is lit when connected anywhere to the surface of this copper ball. That means the electrons in the transformer coil -moved back and forth by the magnetic field of the transformer's core- are able to move all the electrons in that huge copper ball without any effort, otherwise there would be no electric potential between any point of the surface of that copper ball and the second wire.
4) One of the wires is connected to Earth. The lamp is lit when connected anywhere to the surface of the Earth (although more depending on voltage and resistance). What does that mean? Does that mean (without a lamp connected, no current, only voltage) that this little transformer is able to influence (attract and repel) all the electrons located in the entire Earth like the electrons in the copper ball? Isn't that a very queer notion? Or shall we rather call it a paradox?
Could it be that something is wrong here?
One more weird thing (or paradox) about electrons: Two equal batteries are connected in series (without load). Hence, the positive pole of one battery (lack of electrons) is connected to the negative pole of the other battery (surplus of electrons). So what is the condition of the connected positive and negative poles? Is there now a lack or a surplus of electrons? If there is neither a lack nor a surplus (but rather an equilibrium) while the battery poles are connected to each other then how does this change occur? There is no compensation current flowing in the moment of contact, neither between nor within the two batteries. Curious, isn't it?
Now that we know that electricity can obviously act in a very paradoxical manner, we should look for that one paradox that can provide us with free electricity. :)
Apropos ozone: I think there was a Tesla patent called »Apparatus for producing ozone«. But maybe that's just a coincidence.
roll
hello to all !
I'm lost here in all schematic, as I know there is a few typ of construction an all we ''call'' capanadge, can you please someone of us tell me what is the best scheme for first kapange coil ?? I know there is The Donald L. Smith Device, original kapanadze device, SR 193, dally kapagen device....
I will tray to build it, anyone can help with best typ of device??
regards
