0 Members and 344 Guests are viewing this topic.
Zeitmaschine
Quote from: Grumage on September 02, 2013, 04:39:05 PM
Just spent the last hour or so with this one. Now apart from possibly ruining several HV diodes?? I would say "Myth busted"!! Has anyone else tried?
Water Sparkplug II
As soon as the switch opens the magnetic field generated by the primary coil collapses and creates a high voltage spike in that primary coil. This high voltage spike then is stepped up to even higher voltage in the secondary coil, so the spark gap fires. Since the electrons jumping the spark gap are all flowing from negative to positive some of these electrons can pass the diode so the positive pole of the primary coil is connected (through the spark gap and the diode) to negative. That means the primary coil is not simply switched off but short-circuited for a brief moment when the spark fires.
Not sure, but maybe shorting the primary coil instead of disconnecting it creates a similar effect.
TEKTRON
Quote from: zcsaba77 on September 02, 2013, 04:16:49 PM
... and what is the answer? can change copper magnetic property after some months on like his device?
regards zcsaba77
Nickel is magnetic and one proton short of copper.... NMR??  :o
00
Quote from: Zeitmaschine on September 02, 2013, 06:20:21 PM
Water Sparkplug II
hi see image zeit!
00
elementSix
Quote from: 00 on September 02, 2013, 07:18:50 PM
hi see image zeit!
00
I. Don't know about that primary going all the way down.  But it you cut that out with that other switch, you find the resonant point and maybe you will have something.
magpwr
Quote from: stivep on September 02, 2013, 02:33:48 PM
http://www.youtube.com/watch?v=-kO8aMm9uW8
Wesley
Dear Wesley,
That video is fake.I have posted the reply in this topic few days ago.Where i mentioned this tinned(silvery color) wire and copper wire pair is sold in the "audio shop" .I have seen it before.
The part which he used magnet on wire
I don't understand why some people go through this extend to produce a fake video to confuse people more.What do they get in return?
