0 Members and 59 Guests are viewing this topic.
Hoppy
Quote from: Zeitmaschine on September 03, 2013, 12:14:06 PM
But it works: Field Of Fluorescent Tubes Powered By Ambient Current. The high voltage of the power line lights up the fluorescent-tubes.
Question: Are these tubes lit by free energy or is the energy tapped from the power line? I think this is not as obvious as it appears at the first glance.
Think 'Jacob's ladder'.
Grumage
Quote from: Grumage on September 02, 2013, 05:19:59 PM
Evening Hoppy.
Spark plug? We HV men play with bare wires!! :)
Seriously though, If I must!!?? I just created a gap between HT lead and the coil's metal core frame. I don't know if the coils turns ratio is different, they are after all a little smaller but I thought the effect would be seen? Perhaps, as it is such an easy experiment to create maybe another member might like to see?
Regards, Grum.
Good evening Hoppy.
Do you have any more thoughts regarding the above??
I would really like someone else to either verify or discount my findings.
Cheers Grum.
Hoppy
Quote from: Grumage on September 03, 2013, 12:28:54 PM
Good evening Hoppy.
Cheers Grum.
Evening Grum,
I have not built this device but I know someone who did and it does work. I think the electrode has to sit inside the outer chamber as with a spark plug. All I can suggest is try and find an old resistor less spark plug and make sure you don't have any built-in resistance in the HT lead.
ariovaldo
Quote from: Hoppy on September 03, 2013, 11:47:21 AM
Interesting schematic ariovaldo.
Attached is an experimental circuit I may try out. The high permeability toroid mixes the HV/HF with the LV 50Hz and outputs the concoction to a step-up mains transformer. This seems to me to be a more elegant way of doing the SR193 ferrite transformer.
I need to check the toroid permeability that I have. This is some test that I can do next weekend. The diodes that I bought are from China, so I do think I have some spare time until I receive those diodes...
