0 Members and 228 Guests are viewing this topic.
dllabarre
Just a thought....
Could 3a in the schematic be similar to the cage type coil wrapped around the Tesla coil in the image below?
guruji
roll
ok, thanx for all sugestion,
I'm sure I will ask you some question when I start to build it ..
Grumage
Quote from: dllabarre on September 05, 2013, 03:04:50 PM
Just a thought....
Dear dllabarre.
I have been thinking about this one since the patent was first shown here. It reminded me of one of Don Smiths ideas using a Plasma lamp as an energy source. Fuzzy looking area box 2 ??
I have attached a closeup of what I used in earlier experiments to get some high voltage. It is simply a small plasma lamp with an Aluminium jacket. To use the voltage generated you can pick it up anywhere just by touching a couple of HV Diodes onto the jacket. This was then used to charge HV caps. The whole lot consuming around 850 mA.
Just another slant on the idea?? :)
Cheers Grum.
00
Quote from: roll on September 05, 2013, 03:24:36 PM
Hi Roll!
the easiest and safe  with not to hard find parts and workable is barbosa.
so learn about barbosa.
http://www.overunity.com/13721/energy-from-the-ground-self-powered-generator-by-barbosa-and-leal/
http://www.free-energy-info.tuks.nl/Chapt3.html
download patents read them carefully.
tip:  connect two transformers so primary of one transformer makes north and south and secondory induced(that is makes south and north pole. so  you will have NSSN IN  first transformer
connect the two as NSSN-SNNS.
00
