0 Members and 228 Guests are viewing this topic.
00
Quote from: steadyfield on September 06, 2013, 06:39:30 AM
That is a chinese replication of the donald smith device.
see the original post here:
http://www.energysea.net/forum.php?mod=viewthread&tid=1157
and also here:
http://user.qzone.qq.com/278885050/blog/1378191565#!app=2&via=QZ.HashRefresh&pos=1378191565
Please use Google to translate it.
his diagram is in the attachment.
it seems that his replication doesn't need any ground connection.
He (青云Cloud) is also the person who made the 2 shaded pole motors (one modified)  self looping device.
This might not be a fake.
I have one question.
How to calcuate the values of the secondary capacitors to match resonance?
hi steadyfield!
the don smith replication is based on zelina zilano  circuit from energetic forum and is based on reverse tesla coil. with cw and ccw secondary coil.
get an LCR meter. to measure L and then use this calculator
http://www.mackrackit.com/djm/Web/LCR/LCR.html
to calculate cap. there are many other calculators on net. use any one that solves your quest.
ps: watch the spark frequency and compare with kapanadze spark frequency in aquarium video.
spark frequency is slow but has no effect on burning bulbs. lenz killer coil does its work dual way thus power produced is more. the ground earthing will enhance to fetch more power and more brighter bulbs adding barbosa electrons to the circuit. don smith was never wrong nor kapanadze nor barbosa and zelina zilano.
00
ariovaldo
Quote from: 00 on September 06, 2013, 09:22:20 AM
hi steadyfield!
00
Hey 00 !!!
Where did you get this LCR meter?
I got a crap one....
Thanks
00
Quote from: ariovaldo on September 06, 2013, 09:39:37 AM
Hey 00 !!!
Thanks
Hi arivaldo!
i stole it from a guy.
who made it.
00
ariovaldo
Hoppy
Quote from: ariovaldo on September 06, 2013, 09:03:59 AM
In the past, I'd tried several Don Smith's configurations, and I never got more that I put in, but this was a good learning stuff. I'm not saying that doesn't work ( if I didn't believe, I wasn't here in this forum) but for those ones that intend to test, be careful with the High voltage in this circuit.
The input power of a 5KV neon sign transformer will typically be in the order of 100W - 200W depending on its current rating. Given that a setup like shown in the Chinese video will be little better than 50% efficient electrically, then the lamp load will share around 50W - 100W at best. Its not possible to even guess the consumption of the bank of 9 lamps in the video, as the camera is compensating for light and the lamps are flashing wildly. Some key data is needed on power consumption from a watt meter at the input and some scope shots taken across low value shunt resistor in the lamp loop and of course the type and wattage of the lamps used. This data will help those interested, to decide whether its worth trying to replicate this particular Don Smith type configuration.
