0 Members and 209 Guests are viewing this topic.
magpwr
Hi everyone,
I have spotted a easy to understand demonstration video on how to achieve "Resonance amplification".This is the most important criteria for "ou device".
http://www.youtube.com/watch?v=D7QiI8p1gi4
This is the similar concept base on someone whom posted about 2 magnets leading to CW and CCW coil with meter in picture form just few days ago.
core
Quote from: magpwr on September 09, 2013, 10:32:28 AM
Hi everyone,
I respectfully disagree, that's far from the most important criteria for a "OU device". I would argue that the most important criteria is finding an "Energy source" (and it must be a physical one) that allows you to draw from it. As an example, imagine you tapped into a natural gas pocket in your backyard. From this you can power a simple steam boiler, at no fuel cost to you. That in essence is Free Energy. You would be heating water by drawing freely from the earth.
So I would reason that the first question we need to ask, and perhaps the largest to solve is "What physical matter is there that will absorb cosmic energy automatically (for lack of a better phrase) AND will readily 'give off' energy at low cost or no cost to you in the process.
Another small example. Lets say we have a large dark colored stone. We place this stone in the hot summer sun all day. At night we bring this stone inside to an air conditioned room. From being in the sun all day the stone has absorbed some of the suns energy. When we bring it into a cool room the stone 'automatically' gives up its energy to the surrounding environment.  Our air conditioning system, in the room absorbs the energy, in the form of heat, into the refrigerant in the cooling coil (this is the evaporator coil). In turn the refrigerant rejects this heat back into the environment via the condenser coil.
So what did we do? we basically 'charged' the refrigerant with energy from the sun in a very indirect manor BUT a very efficient manor.
By efficient I mean:
1. It did not cost me anything to charge the stone with the sun's energy its a natural process.
2. It did not cost me anything to reject the absorbed solar energy from the sun, again another natural process due to the rooms heat energy level being lower then that of the stone. By having an air conditioner I simply created an 'environment' for the natural process to take place. (in theory I didnt need an air conditioner, an underground room or a cave would create the environment)
3. The refrigerant naturally absorbed this released energy simply because again, I created the correct environment for the refrigerant to do so naturally.
4. I then rejected this energy back to the environment PLUS extra energy from 'Heat of compression'.
So in essence the Suns energy came in at a specific energy level and left (back to the environment) at a higher energy level. Higher because I had to use some energy to compress the refrigerant to a higher pressure/temperature.
I have always been fond of this specific Tesla quote:
"there is no energy in matter other than that received from the environment."
- Find something that rejects it at low cost, or no cost.
- Absorb it.
- Add to it.
- Reject it.
Too simple right?
Ok my Two Cents for the rest of the Year.
- Core
magpwr
Quote from: core on September 09, 2013, 09:59:15 PM
- Absorb it.
- Add to it.
- Reject it.
Too simple right?
- Core
Hi Core,
I would agree base on what you quoted as above might be applicable to most "common" matter we normally know or get our hands on.Mica used in early radiation detectors uses natural radiation to produce tiny voltage as an example.
May i ask what do you think of this particular matter "Barium Titanate" which do have a  strange ability to "amplify at resonance".
This is the site which experimented with Barium Titnate and Barium Ferrite magnet to prove "ou effect"
http://www.rexresearch.com/mra/1mra.htm
Barium Titanate RF test-This is very interesting experiment on "cold current" where high voltage bulb can be lit touching on 1 wire without shocking the user.
http://www.youtube.com/watch?v=NklUWctiqcg
I have already done experiment with Barium titante chunk bought from ebay.At this moment without Barium Ferrite magnet using just 45 Bifilar winding on 3" iron powder toroid i'm already getting ou in mW and load to bifilar coil <1uA via Barium instead of direct connection and voltage amplification at output of bifilar winding.But using direct  connection to bilfilar coil from signal generator (40mA)with no increase  in voltage from output winding.This is base on the 1st link rexsearch i have provided.Currently am waiting for Barium Ferrite magnets to be delivered to me from China.This will allow me to create a close loop unit.
In fact the only way to prove me wrong or fake is that you try it out first."Please do not be a (Armchair Occultist) or people whom just do talking and disccuss about theories merely on how thing works" .
Please note nearly all theories(Found in school text book) was concluded with a experiment by it's founder or inventor.Merely discussing theories over and over again will just kill time especially those which is not proven yet.
Hoppy
Quote from: 00 on September 10, 2013, 02:21:40 AM
hendershot free energy!
http://www.youtube.com/watch?annotation_id=annotation_838019&feature=iv&src_vid=wJwKemnEUko&v=BJ2H2BHTjuo
00
Doctored motor - battery in casing. The iron loop acts as a conductor to complete the circuit. He has probably used a miniature motor inside to make room for a small lithium button cell. Lets see him do something really clever and swap the motor with a miniature 'vibrator' type motor from a mobile phone.
