0 Members and 220 Guests are viewing this topic.
a.king21
Hoppy and all:  You should watch this video in it's entirety. It's by Dr Judy Wood.
http://www.youtube.com/watch?v=T1NbBxDGSkI
ariovaldo
Quote from: Hoppy on September 03, 2013, 11:47:21 AM
Interesting schematic ariovaldo.
Attached is an experimental circuit I may try out. The high permeability toroid mixes the HV/HF with the LV 50Hz and outputs the concoction to a step-up mains transformer. This seems to me to be a more elegant way of doing the SR193 ferrite transformer.
Edit: Schematic modified.
I'm still waiting for diodes and some others part to build the circuit based on microwave circuit.
Meantime, I received a used ( but in good conditions) a 3 phase 25 kVA transformer 460/220 volts, that I will used for tests. The primary is in the top of secondary and I will take out the Delta connections making the coils independent of each other....I will start energizing one of the primary coil with 110 volts and try to understand in a practical way, the relationship between the phases and etc... I'll use dc in one coil to see the effects...
I'll start this test in the coming weekend.
Let me know your thoughts about that.
Have a great and blessed day.
a.king21
Ariovaldo:  Tariel mixes static with ordinary power. Look at Tariel's builds and see where the HV shielding is. He generates HV (static) by high frequency switching then mixes it with ordinary electricity. As does Carlos Benitez in his 4 battery patent of 1915-1916 . I've replicated Benitez.
Look at my last post and look at the video by Dr Judy Wood.
Good luck - good to see an experimenter here.
MenofFather
I think, to work free energy divice, need make preshere, that energy come from graund, this maybe possible make only with hight voltage. Simplest way is use good graunding, Stev Mark not use graund, but it divice more complex. Simplest schematic is make Tesla coil, put on 2 meter of gronf and some space of coil big toroid or globe or plate and to it paste wire from secondary tesla coil andbetwen buttom end of tesla coil and graunding tick wire try put incandel or hologen light bulbs from 50 wats to 5 kilowats (5 kilowats you probarly not find, so put toaster and acros it 60 W light bulb). And changing lenght of ground wire. And you then maybe get from input about 40 W about 0,05-2 kilowats. Spark gap frenquency maybe can be hight and maybe, can be not hight. Primary coil let say on 6 cm tube wound abou 10-70 turns, secondaryt on 5 cm tube 2000-7000 turns. Need experimenting with diameter primary and secondary tubes and wires.
ariovaldo
Quote from: a.king21 on September 10, 2013, 02:03:14 PM
I'll try to take note and show the results. I got in my mind that I need to simulate some points.
