0 Members and 346 Guests are viewing this topic.
ariovaldo
Quote from: MenofFather on September 10, 2013, 02:16:39 PM
I think, to work free energy divice, need make preshere, that energy come from graund, this maybe possible make only with hight voltage. Simplest way is use good graunding, Stev Mark not use graund, but it divice more complex. Simplest schematic is make Tesla coil, put on 2 meter of gronf and some space of coil big toroid or globe or plate and to it paste wire from secondary tesla coil andbetwen buttom end of tesla coil and graunding tick wire try put incandel or hologen light bulbs from 50 wats to 5 kilowats (5 kilowats you probarly not find, so put toaster and acros it 60 W light bulb). And changing lenght of ground wire. And you then maybe get from input about 40 W about 0,05-2 kilowats. Spark gap frenquency maybe can be hight and maybe, can be not hight. Primary coil let say on 6 cm tube wound abou 10-70 turns, secondaryt on 5 cm tube 2000-7000 turns. Need experimenting with diameter primary and secondary tubes and wires.
I agree with you and I think the ground charges to be attracted needs to have a high voltage differential....and more than that...an environment where the electrons can inrush from one point to the other easily and in abundance..
forest
energy does not come from ground and not from electrons, recall what Don Smith said about his plasma globe device; he was the magician of indirect tips like Steven Mark also
captainkt
@ariovaldo, please keep us informed as I have same transformer in my workshop had to use mini digger to move it. I have not started yet as when I looked there are so many windings to sort out. Looks as if you are saying split the 3 main coils first.
Keith
ariovaldo
Quote from: captainkt on September 11, 2013, 05:13:36 AM
Keith
I will let you know Keith.
After doing some test as the transformer is, I will try to disassemble the core without damage the winding, so I can have space to use a thicker 2 turns cable.
bbem
Quote from: forest on September 10, 2013, 04:43:59 PM
Is this what you are telling us?:
http://www.youtube.com/watch?v=pOZe--avlaY
