0 Members and 475 Guests are viewing this topic.
bolt
Quote from: romerouk on June 10, 2010, 06:55:21 AM
The capacitor is used in parallel with the load, that is the case when powering system with high voltage ac. It works ok without it but it kills the bulbs very easy. Having the capacitor connected it cancels some of the spark i get inside the bulbs.I think the solution is not high voltage ac, system is more stable and controlable using dc.That was my first attempt.I can see already more advantages using High Voltage DC.
Sometimes 'logic thinking' kills the  good results.It's been proven to me many times. Not everything works as we learned already.It is good to try even ilogical ways.
Capacitor across the load is changing the LCR tank thru the earth to lower frequency. It should be more effective however to change the tank across via fat 6 winding add caps there instead because this is your secondary low voltage coil.
This Tesla based system IS supposed to run on DC pulses. Straight off the bat you save 50% of your power going through diode as only 1/2 of the wave pulses are going through thus you see instant power saving effect and cooler spark plug.
Naudin KAPAGEN bear bones AC MOT system is sledge hammer to crack a nut its raw unrefined BRUTE force. It can only run like this for a few minutes at best and far from a  lasting solution before something catches fire or melts.
Dont get confused though it may appear to be DC but its VERY much an AC system as spark gap is a frequency shifter from 50hz DC pulses to somewhere around  15Khz AC in the KAP coils.
YES and if you dont lower the frequency properly after voltage change light bulbs WILL jump filament inside and arc internally. They don't like 15Khz very much.!
Oh last thing my thought on coil winding direction. DOESN'T MATTER! Only total turns and diameter of coil will change things.
Don Smith probably understood more then anyone how these systems work. Thru conventional eyes is makes little sense but in essence even from RF point of view this is a base driven 1/4 wave tesla coil where 20 turns is 1/4 of 80. or 25 base driver is 1/4 of 100 turns etc.  Reason is GAIN 2kv may be as much as 8kv end to end on the Kapa coil. More volts = more joules. If you got too many volts coming out  then take a turn off the 6 fat coil.
forest
In fact if you look at that coils it is exactly flyback coil with connected extra coil in non magnetic way (opposite to flyback secondary). Like car ignition coil with additional extra coil in non inductive position.
I bet it is releasing radiant energy captured by that extra coil which moves electrons in wire connected to load and also from ground in oscillating manner.
Is it possible to  replace spark gap with something much more stable and choosing one frequency of operation of device without much diminishing output power ?
xenomorphlabs
Quote from: hartiberlin on June 10, 2010, 07:19:23 AM
Can somebody please post a summary,
what this guy says in this video ?
Does he speak Russian language ?
http://www.youtube.com/watch?v=47RtzJliOpA
He also shows some scopeshots and these are really very noisy RF bursts
powering the light bulb.
Stefan,
he does not speak russian for sure.
It´s maybe bulgarian or something like that.
woopy
Hi Romerouk
As your kapagen replication works and as i would like to replicate it also, can you please say which winding you use A or B.
Thanks
Laurent
baroutologos
ADMIN:
Does he  language ?
hello Admin,
This guy is a Bulgarian located in Madrid, nicked-named Mito Kupona, active in the http://mazeto.net/index.php/topic,1546.300.html?PHPSESSID=jql0aebilmauclcl4o1lhgtb36 site.
We have communicated, he particularly discusses his work-schemes with his bulgarians collegues.
This work is based upon SR's teachings.
In short a NPN-PNP transistor inverter setup is being controlles by a 555 timer circuit operating at 50Hz (simulating SR's).
The coil is a biffilar one wound over a ferrite core. He applied to one winding (running in parallel to the biffilar) a HV that comes from a flyback transformer via a spark-gap and a diode.
He initially thought that the high frequency generated energizes the magnetic domains of the material and the faint power (faint bulb glow) of the inverter alone is enhanced to make the bulb bright.
As he consequently found out and you can see by the weird current reduction/voltage drop in the lab PSU the HF RF messes around with all measuring equipment and first of all the 555 timing circuit making it speed-up.
Madsatbg verified the same thing after all, as me
http://www.youtube.com/madsatbg#p/a/u/2/Uj1FWXbhyO0
http://www.youtube.com/madsatbg#p/a/u/1/4v2uxVd3Mo0
For alliminating this problem I personally run the NPN-PNP inverter trans pair with a small step-down transformer driven by the mains. This way the signal could not be messed around since mains frequency, with RF does not alter. (and rf is little to power the transistors)
This is what i know by the way so far
