magpwr
Quote from: lightningengineer on September 12, 2013, 11:29:33 AM
I am an engineer and obviously know a damn sight more thatn you if you are asking such foolish questions
IM quite aware of why the hell teslas financiers didnt want wireless power.
TRY to make you LOOK like clowns? ???  Mags...youre doing that allllllll on your own.
Well the answer your question about sine wave inverters.  OMG.  youre thinking in the wrong spot.  Who said he needed a battery?  But please carry on stumbling in the darkness by all means.
hi lightningengineer,
I don't blame you since you are new to the post and so am i less than 3 months.I understand(school text book) never never teaches free energy(overunity).Only losses in everything,nothing is 100% or 110%.
By the way i don't like to talk theories over and over again since as you would know nearly all theories in books was concluded with a experiment by it's inventor.
I'm not here to speculate and kill people time but here to understand and experiment if the device is for real.
fyi-I have already achieved ou in mW without Barium magnet(pending delivery at this moment) merely using Barium Titanate base on 1st link shown below.
After which it will be a close loop device.I have previously posted findings.
This is the site which experimented with Barium Titanate and Barium Ferrite magnet to prove "ou effect"
http://www.rexresearch.com/mra/1mra.htm
Barium Titanate RF test-This is very interesting experiment on "cold current" where high voltage bulb can be lit touching on 1 wire without shocking the user.
http://www.youtube.com/watch?v=NklUWctiqcg
Last year i create a very simple circuit base on 1 x peltier module to human body which generate heat 24x7 to provide unlimited useful electricity as we sleep(useful for military or mining hat).
search youtube "ultra lowest 25mV" IN YOUTUBE.
This year i have just started study on this kapanazde device and other free(overunity device).Prior to that i had created "1 WATT hho generator".But this project is back to drawing board as i needed to improve hho production much further at lower power.This experiment is the most costly since price of stainless steel 316L isn't cheap.
My experiment is purely for personnel knowledge and shared to public aka youtube.
stivep
Quote from: stivep on September 11, 2013, 09:09:20 PM
Quotes of  Wesley from  Youtube notes at:http://www.youtube.com/watch?annotation_id=annotation_321531&feature=iv&src_vid=BJ2H2BHTjuo&v=wJwKemnEUko
Hoax,
----------- coil---------------- the lines are hanging wires of dipole antenna . the frequency of transmitter is tuned to resonant frequency of shorted winds by "magnet-short clamp" That means shorted  winds  by shorting bracket ( in this case magnet) tune entire coil to preset frequency of  transmitter.
You can  also do it reverse. Simply tune transmitter to coil without  magnets at all but than there would not be " magic influence."
Many will  immediately see B.S. in its  easy to smell form.
Magnet is not important it just short wires to reach tuned frequency of transmitter.and change capacitive and inductive components of coil.
The approximate properties of coil at 3.0099 MHz - C=4.66nF and 600nH at say 6 winds of 1.74 inch diameter. I did not yet take to calculation dipole at 1/4 lambda
B.S Big time
Wesley
I actually took  random coil
picture below
Put it on  Wayne Kerr Precision Magnetic Analyzer PMA3260
At random 3MHz I found 600nH and 4.66nF
Than I went to calculator to check my  readings
http://www.siversima.com/rf-calculator/lc-resonance-calculator/?gclid=CJSiyvDOxLkCFURp7Aod-2gAYw
it shows  me   frequency of response  3.0099 MHz
I did not include the two hanging wires as of yet as a dipole say 1/2 lambda- that would indicate that  real frequency could be much much  higher
any how who cares  plenty of frequencies would work there. you have also complication with vertical  coil I call it "idiots coil"
questions
1: So how many idiots one idiot can make?
2. what an idiot is making this video for?
answer: Low Low Self-esteem
and gain of money by gaining more viewers due to  adds on his channel..
I do not have any adds on my videos.........why?
Because I do not scam people.
Wesley
tsbrownie9 hours ago
Where do you propose the transmitter is that it could deliver enough power to run a motor or measure out at 1.4+ volts on such a small, ungrounded antenna? I show the room around it. A transmitter that it could be 4-5 meters away and deliver that much power would be fatal. Most received power is in the micro watts.
Replyreply to stivep1
stivep11 second ago
Link at higher frequency permits use of smaller antenna. e.g: assuming that -Tx and Rx antennas are the same; -no change in efficiencies,medium or transmit power; Question: HOW MUCH POWER DECREASE OR INCREASE AFTER FREQUENCY IS DOUBLED? Answer: Pr2/Pr1=(F2/F1) squared so Pr2=4Pr1 The received power at receiver  quadrupled as frequency was doubled From that I state that You can use 4 x smaller power TX at twice higher Frequency to get to the same power at motor. 100% your video is HOAX Wesley
in reply to tsbrownie
stivep1 1 second ago
Kenwood 2000 :100W HF/2m/70cm. e.g A 150 MHz VHF transmitter delivers 20 W into an antenna with 10 dB gain. Compute the power in W available from a 3 dB gain receiving antenna 20 km away. you will find out the level of 25.3nW at any given voltage at antenna. Power= voltage x  current but
Power  =  I square x R where R is impedance .
Impedance is than  as equivalent of series/ parallel or one of it.And is made out of  C and L  remembering that mostly R( resistance) is omitable
If antenna is at capacitive character and depends at what point of an antenna you put your probe at- than you can have 10V and more. Got IT? Put motor ant the end of wires The world is full of lies Wesley
stivep1
I will help you out calculate this.
F=150MHz=2m;Pt=20W;Gt=10db=10;­Gr=3db=3;R=20000m; Pr=PtxGrxGtx lambda-square/4piR-square = 25.3nW.
Coming from that you can find that at distance of 100m you can have any voltage you want depends on antenna( 2 wires+ HOAX coil= complex impedance)
As long as it matches impedance of motor coil.
Please read comment starting from:Link at higher frequency permits use of smaller antenna.
Wesley
stivep1  to tsbrownie
you dragging me to your"I DO NOT KNOW" world. Well I Know it is a hoax.
1.Cut the hanging wires and show the motor working
2. use copper shorts instead of magnets show on meter as you did with magnets
3, Show motor working at the same sequence with motor connected to ends of the wires and than next motor terminals.
4. put coil in Faraday box and show it working]
5. take it to the open field walking with it for a mile while in swimming dress. Do it and than we take it from there.
Wesley
magpwr
Quote from: stivep on September 12, 2013, 12:35:27 PM
stivep11 second ago
Kenwood 2000 :100W HF/2m/70cm. e.g A 150 MHz VHF transmitter delivers 20 W into an antenna with 10 dB gain. Compute the power in W available from a 3 dB gain receiving antenna 20 km away. you will find out the level of 25.3nW at any given voltage at antenna. Power= Voltage x impedance If antenna is at capacitive character and depends at what point of an antenna you put your probe at- than you can have 10V and more. Got IT? Put motor ant the end of wires The world is full of lies Wesley
stivep1
Wesley
Hi Wesley,
I have seen that "inventor" video with the motor.I find it little fishy why because even it was powered by a transmitter from a distance there is no diode(detector diode) or bridge diode to rectify the voltage to motor.
Final and easy way to unlock the locking pins beneath the motor so that it's inside can be revealed and then close motor cover to show ou effect.All this in 1 continuous video shot. :D :D :D
Hoppy
C'mon lads, don't get taken in by a simple fake.   :( The motor is doctored - simples!
MenofFather
