0 Members and 179 Guests are viewing this topic.
MenofFather
Here similary shematic, so I post it, and it also maybe overunity. http://i38.servimg.com/u/f38/15/04/69/67/65nw10.jpg Here also ground need to disable hight frenquncy noise.
Gidfactor
Good day guys... Just came across this very interesting idea on YouTube and decided to share it...
Cheers...
http://www.youtube.com/watch?v=FckGSsSCHHw
a.king21
Quote from: Gidfactor on September 29, 2013, 11:08:46 AM
Cheers...
Yes, it's what I've been on about. However it's pure Bedini.
BTW if you remove the clamping diode on the Bedini ssg and put it in attraction mode - it goes OU on both primary and secondary batteries -
forest
Quote from: MenofFather on September 29, 2013, 06:59:57 AM
In Scheme nren12 to replace or any other nrenZB 12 volts.
The fan on the 12 volt computer blew radiators with inverter transistors.
Transistors need to pick up on the same parameters, then the fan is not needed.
Distance only by experience - from 0.8 mm ...
ground needed to reduce high-frequency noise on the output of the installation!
While it is possible to feed the lamp, and TZNy alektrodvigateli well and samozapitka ...
For the best possible sinus 220 50 Hz output should be put D - D (motor
- Generator).
Naturally capacity depends on the inverter capacity.
Please add corrections. This scheme , previous and all I saw with ferrite core is based on magnetic amplifier. The high frequency MODULATED current has effect on hysteresis of ferrite core and impedance of low frequency circuit.
Hoppy
Quote from: a.king21 on September 29, 2013, 11:22:05 AM
??? Really! - have you just returned from the pub!!
