0 Members and 41 Guests are viewing this topic.
br549
Quote from: T-1000 on September 29, 2013, 06:55:23 PM
Also you might read old John Bedini page in http://www.icehouse.net/john1/intro.html and see those energy generators patents. It is full of clues what to look for.
While trying to reduce the RF emissions from my Colman Test Unit for personal safety and reducing the potential for false reading from the measuring equipment (giger counter, etc) I noticed that when I applied a DC pulse to the coils in the reaction chamber (used to provide a magnetic field across the Colman Tube) that the giger counter reacted to it.  http://youtu.be/C6xFqE4301o
I am not going to make any SWAGs, but it seem to have a familiar Bedini ring to it, as far as spiking a Lead Acid Battery with a fast high voltage pulse to cause a reaction in the battery, so I decided to do a little follow-up on it and share the results. http://youtu.be/LXtYB4PDXf4
As always:Have a Good Day.
T-1000
Quote from: br549 on October 02, 2013, 10:56:15 AM
If you would bring Geiger counter near Tesla coil it would scream :) The inert gas is being ionized near exciters intensively.
Also to identify what is emmited exactly the better equipment is needed so you could see type of emission and what particles are ejected. Usualy they are alpha particles around coils and surrounding electronics in excited mode but also you might find something unusual.
Cheers!
Zeitmaschine
Quote from: stivep on October 02, 2013, 01:57:28 AM
http://www.youtube.com/watch?v=wuoISZAlFAc&feature=youtu.be
Wesley
I can't see how all this electronic stuff could ever fit into the tiny tin can on Kapanadze's table, and also I can't see any huge classic Tesla coil on Kapanadze's table. So I don't know whether this Akula device really works or not (fake), but I'm sure it is in any case more complicated than necessary.
My current state of experiments: Two HV transformers connected together so the lamp lights up without a closed circuit. Have burned two HV transformers already, don't know if this means something regarding OU. And I don't know what this means regarding the Lenz's law. Is Lenz's law applicable without having a closed electric circuit?
Touching the high voltage connection between the transformers (even with isolation) reduces the brightness of the lamp. Maybe this could be a good reason to shield it, like with Kapanadze's tin can.
This is two Tesla transformers. They are connected through a wire from the top. Between them must be a resonance. First transformer works via spark on 100 kHz and higher. Second - is a power transformer. In the first transformer we have small capacitor on primary coil for the high-frequency discharge. On secondary coil (power transformer) we have large capacitor for decrease our high frequency. In the output of the Turk device are powerful diodes. They fix output energy. Next step - it passes through a capacitor and then formed 50 Hz.
Hence next step should be to connect the lamp not straight to the output transformer but via an inverter that provides 50Hz. If there is ever free energy in the high frequency high voltage circuit then mixing this high frequency with 50Hz low frequency should transfer (or suck) the energy into the 50Hz output circuit according to Rhythmodynamics. Will see how many smoke clouds this method can produce. :( ::)
But if Tesla's Magnifying Transmitter really magnifies (the power, what else could it be?) then I guess something unusual should happen here.
dllabarre
Quote from: Zeitmaschine on October 02, 2013, 02:10:41 PM
Are these 2 transformers identical to each other?
DonL
T-1000
Just an addition:
Add third coil to receiving transforner for withstanding lots of current then put it in series resonance. Then see how spark discharge between two high voltage ends affects output of receiving coil.
Cheers!
