0 Members and 59 Guests are viewing this topic.
e2matrix
Quote from: woopy on June 10, 2010, 09:06:11 AM
Hi Romerouk
As your kapagen replication works and as i would like to replicate it also, can you please say which winding you use A or B.
Thanks
Laurent
I'm not sure about this but I think I would avoid A as it looks too close to a caduceus wind which might generate a dangerous amount of scalar waves at these power levels.
bolt
As already said coil direction windings makes ZERO difference on this design. Only number of turns and diameter will change things.
e2matrix
Quote from: bolt on June 10, 2010, 12:47:33 PM
i don't mean add a wire across i mean add a GDT across each bulb or load is standard practice. Don Smith devices use a lot of GDT's for controlling various systems voltages.
I understand now.  Unfortunately our English language can have many meanings to one word depending on it being a verb or noun just to name a few.  I took it to mean you were adding a wire but understand now you meant to wire in the verb sense a GDT across it.  Sorry for misunderstanding.
dllabarre
@romerouk
2 more design questions: (i can hear you now "not another one")  ;D
What diameter pvc pipe are you using?
Schedule 40 or 80?
Post either inside diameter or outside diameter and I can figure out the other.
Thanks,
Don
Zic Hailev
I assume that the wire which is passed{missed} through the coil on the center, it is a wire which the coil connects bifilar a winding of the coil and after that it{he} is twisted with an ground wire, that is ground bifilar. :-X :-X :-X
