0 Members and 622 Guests are viewing this topic.
forest
v8karlo
Quote from: a.king21 on October 17, 2013, 05:48:53 AM
A year  ago a guy called v8carlo (or something like that) got his secret in my opinion.
It didn't mean anything to me at that point because I was concentrating on trying to get the tech to
the West. Anyhow I think he figured it out.
There are many ways.
Yes, there are few different ways.
There is method which do not involve any coils at all. It multiplies Amperage but the voltage stays same as input voltage,
but this is not point of my reply.
Last thing that I am been working on is Tesla one wire system and how to fill capacitor using weird ways to do it.
One of them is in the pdf and it looks to me like Tesla Magnifying patent. In the patent one plate of his capacitor is
metal ball at the top and other plate is ground, and in his time he didnt have diodes, but the construction is pretty much
same as mine. The third coil act as inductor. Property of inductor is to change phase, so current at the beginning of
the inductor is at different phase compared to current at the end of inductor. Difference in phases means voltage.
You must drive Tesla coil with at least 15-20kHz and more with small duty cycle to provide lots of small kicks for inductor
to change it to usable energy. Higher the freq., smaller duty cycle (input consumption stays the same), more kicks - higher output.
It is the method which converts freq. (number of kicks) into energy at same input consumption.
I dont have Tesla coil. I am using mosfets to drive my TV flyback but it is the same thing, any high voltage trafo will do
the thing. I use only mosfets because of their speed, and I didnt try any other type of transistors for driving.
This is only the principle, sooner or later you will figure out how to provide large hammering kicks at lower
frequencies using two Tesla coils (two hi voltage transformers) at input for more rapid charging output caps.
One to raise the voltage and hammer the second.
The grounding at cap leg doubles the output. Try without it and with it and you will see.
I wish you good luck with this effect. Cheers.
gyulasun
Quote from: forest on October 17, 2013, 03:06:31 PM
be precise - what is your question ?
Hey forest,
Verpies did not have any questions above.  IF you look up your English-P dictionary, you will probably find out what the word 'second' means as a verb.  Hint: search it for instance as:  to second a motion etc because it has several meanings.  (Verpies supports / agrees with those questions i.e. he also awaits answers for the questions baroutologus asked.)
I also notice you continue laughing at others. Please do not do that.
Thanks,  Gyula
scratchrobot
Quote from: v8karlo on October 17, 2013, 03:55:16 PM
One of them is in the pdf and it looks to me like Tesla Magnifying patent. In the patent his one plate of capacitor is
the same as mine. The third coil act as inductor. Property of inductor is to change phase, so current at the beginning of
This is only the principle, sooner or later you will figure how to provide large hammering kicks at smaller
frequencies using two tesla coils (two hi voltage transformers) at input for more rapid charging output caps.
Can you post a schematic of the circuit you are using now with the mosfets?
v8karlo
Quote from: scratchrobot on October 17, 2013, 04:09:06 PM
This is my NE555 CMOS oscillator. You dont need dead time part, so you cut it out, and you need
mosfet driver at output, I use TC4420 for that.
