0 Members and 139 Guests are viewing this topic.
Acca
 http://www.youtube.com/watch?v=6AZAjsdiNeM
It seems that the nuclear spin of the electron is critical to extract electrons and a theory is still not understood by may,
the above video shows a magnetic torroid with it's magnetic spin waves.. IT's CRITICAL to understand the Akula device...
Ferrite core spin.
Ferrite cores are based on the fact that all fields become established through Hertzian waves, and although we usually consider that fields contain energy, they really are only indicators of the relative energy level existing with reference to the space or material about which the field is to be found.
When electrons are accelerated their relative energy levels are changed, and the indicators of this condition move into position as Hertzian waves. The fields within ferrite are due to changing energy levels of atoms with singular spins. These are reoriented as a result and in response to, the field (indicators) of the accelerated electrons in the wire.
This means that the singular spins are rotated, which in turn produce more fields (indicators) which in turn induce further rotation. The net result of all this is that a sequence of spin re-alignments takes place within the ferrite which moves through the ferrite with a velocity equal to the velocity of light in free space, divided by the square root of the product of the effective permeability and dielectric constant. These last two quantities are not quite what we have been taught but our ideas are close enough to be useful.
Now, the wave progressing through the ferrite must travel at the same velocity as the inducing wave in the surrounding wire. However, as the singular spins are rotated into new positions they obey perfectly normal vectorial laws, in three space and three field dimensions, and in so doing generate doughnut-shaped waves which comprise of closed electric and closed magnetic fields. They are literally pushed out of the far end of the ferrite core and sent merrily on their way.
It's not that hard to grasp this concept, look up the Wesly's  link to the Russian scientist.. above ...you will have to translate it yourself.
Acca...
[/font]
FreeEnergyInfo
AKULA0083   SXEMATIC
www.realstrannik.ru/forum/48-temy-freeenergylt-antanasa/129332-ustanovka-akuly-povtorenie.html?start=360#162851
verpies
Quote from: FreeEnergyInfo on October 18, 2013, 04:55:03 PM
AKULA0083   SXEMATIC
But what is the energy generating principle?  Clapping ferrite halves... ?
Certainly a Schmitt multivibrator, a PLL and a rectangular push-pull transformer driver are not energy generating components.
Anyway, it is uncommon to see a circuit that is not disregarding phase relationships - that's why I'm even responding to it.
Any waveforms or tuning instructions in English ?
NickZ
  It looks more and more complicated with each additional version. I guess that's life.
  I see that he doesn't use the same yoke or air coils combo this time, and he doesn't have insulation between the yoke core halves, and the clips are still present.
  I wonder is this last version has more output than the previous 1150 watt one. It should.
  Lots of Fets, and capacitors, as well. Does it also need an earth ground? Who knows... anyone?
MenofFather
Quote from: NickZ on October 18, 2013, 08:11:34 PM
Erch ground needed.
