0 Members and 44 Guests are viewing this topic.
Zeitmaschine
Quote from: NickZ on October 18, 2013, 08:11:34 PM
It looks more and more complicated with each additional version. I guess that's life.
And I guess that's strategy in order to keep people busy with over-complicated non-proven schematics.
Now I'm waiting for Akula's 3-phase version of his device driving a big 3-phase motor like TK did. :D
Acca
"But what is the energy generating principle?  Clapping ferrite halves... ?" (you may want to save this explanation as it is a secret of the ferrite toroid)
"Secret Russian" explanation what is really going on in that TV ferrite of "Роман Карноухов" Akula0083.. [/color]
By
Vladimir Akimovich Atsyukovsky - doctor of technical sciences, Academician of the Russian Academy of Electrical Sciences.
Sorry these clips are only in Russian, however an explanation is provided below....
http://www.youtube.com/watch?v=L7ciXpTSEKU
http://www.youtube.com/watch?v=RnsM2dQ2AFc
The only structure that hold compressed ether in a confined space is a toroid - closed on itself vortex.
(as you can see from the photos that the core is NOT Split, this is very important)
The fact that the outer surface of the toroid toroidal speed component decreases, but the overall flow rate is stored and converted into circular motion. On the surface of the toroid appears helical motion . This movement spread to all the surrounding toroid space. Comparing the dependences of the toroidal ring and movements with the magnetic and electric fields , it is possible to make an unambiguous conclusion that:
Toroidal flow is two particles create deploying moments as well, as do the magnetic moments of protons. The conclusion on the equivalence of the toroidal flow of aether around microparticles and their magnetic fields.
Circumferential velocity field generated by the toroid, and the electric field of the proton integral describes Gauss, with the attraction or repulsion of two particles to each other by Coulomb's law, the polarity of the particles is determined by the sign of a screw motion.
From the Gauss theorem connecting the electric induction with electric charge  we find an interpretation of the electric charge as the value of the circulation of the annular flow rates of ether on the surface of the proton.
A simple calculation shows that the rate of ether flows on the surface of a proton is about 1021 m / s, ie, many times greater than the speed of light.
Since each vortex is an elastic body Beat particles deposited on the core of the atom, cause such waves, which spread in the body protons and asynchronously on their surfaces due to different elastic bodies proton nucleon-nucleon and the environment. Passage of the surface of such waves cause the external air waves - electromagnetic radiation. Passage of waves in space nucleon-nucleon force nucleons move apart , in unstable nuclei may lead to collapse. This is the essence of the weak nuclear interaction.
All electrical and magnetic quantities can be interpreted as the mechanical motion of the ether, which directly follow from the general concepts of physical invariants .
Electric charge particles is interpreted as the circulation of flux density at the particle surface ether. Hence, the electric field becomes meaningful helical tubes ester (" Faraday tubes ") with a variable cross section factor screw.
An electric field, which is itself at the speed of light, it is impossible to disperse the electron is more than the speed of light speed. This occurs asynchronously effect ( effect of reducing the same force acting on the rotor of the induction motor ) , which reduces the force exerted on the electrons as they approach its velocity to the velocity of light .
It is currently believed that the electric current - that movement of electrons and electron transport it provides the appearance of a magnetic field around the conductor . However, the calculation shows that the conductor section of 1 mm 2 in the speed of the electrons along the conductor is of 6.25 x 10-6 m / s, while the flow rate of ester in the magnetic field on the conductor surface is 1 , 06,105 m / s, which implies that the appearance of the magnetic field around the conductor can not be a consequence of the movement of electrons.
However, everything comes at a match, when you consider that the movement of electrons in a conductor is necessarily accompanied by their turn, spin orientation along the wire.
The consequence of this shift is the movement of live streams, which is outside of the conductor, which is perceived as a magnetic field . In this case, the magnetic field is the velocity of the stream. Tension of 1 A / m corresponds to the flow rate of the ether in 376.65 m / s . The magnetic field itself is not accompanied by a laminar flow of ether around the conductor experimentally that such a course not. The most probable structure of the magnetic field is a structure consisting of adjacent helical toroidal vortices of ether  are a result of the surface of the conductor ring ether velocity at the surface electrons, which themselves are sealed screw toroidal vortices of the same ether.
Wow and thanks to  "Roman" (Роман Карноухов" Akula0083) !!![/color]
Acca....
Grumage
Dear All.
Would I be correct in saying that the above schematic is Akula's "Sound to Spark" modulator??
I base the statement on what appears to be an input at the top left corner. And secondly I recently saw a video of a pair of Tesla coils working to music!!
Cheers Grum.
a.king21
AKULA:  It's so complicated you'll SCREAM.
KAPANADZE:    It's so simple you'll LAUGH.
Acca
 Here is the free energy book by
Ацюковский Владимир Акимович
(will have to use google translate, the book is fantastic)
http://konzeptual.ru/downloadable/520/11Energy.pdf
