0 Members and 476 Guests are viewing this topic.
hartiberlin
Hi romerouk,
can you please just connect the earth cable to the other side
of the coilstack to the center multiple twisted wires and see,
if this produce the same brightness with the same amperage input ?
Yes, please keep the current design,
but just try these small connection changes, please.
This will get us more insight, what is really going on...
And also, if you have a scope, just use a small pickup coil nearby to
see, what frequencies are involved...
These are probably also some kind of Khz to Mhz noise burst radio
frequencies.
Would be interesting to rectify the  output via a graetz bridge and hook a cap
across it to dampen the hash and see if you can run the lights
a bit more flicker free..
The ultimate test would be, if you would use another MOT and run its 240 Volts input from
the output of your circuit and use its High Voltage output via a rectifier to produce the High Voltage
DC that you need.
This would be a selflooping device which you would need to use some kind of over-voltage
protection, so if it would rise and rise the voltage it could disintegrate in a few seconds,
which would be pretty dangerous at this power level !
So you might just hook up some kind of fuse between it, which would blow then
or use some kind of zener diode or
fluorescent tube lighting overvoltage protection  to suppress any runaway...
Many thanks again for your great work !
bolt
romerouk i see you been to Maplin today and bought a new meter:)
Some people connect two MOT's in series for big tesla towers but i strongly recommend you dont try it unless you REALLY know what you are doing. At 4Kv+ its will reach out and grab ya!
hartiberlin
Hi All,
I watched this movie from SR again
and ask myself how he is supressing the runaway with his unit ?
http://www.youtube.com/watch?v=-lhvfh3MDfc
I think this is no fake.
So how does he protect the runaway in his selflooping and selfrunning
unit ?
Regards, Stefan.
romerouk
I will try to take pictures when I will build the new coil. I will concentrate to get 240ac out.
I am not verry happy with the results so far...
I have this extra energy but it is not useful because of the spark gap overheating, too high voltage, fluctuating voltage.At this moment we have proof that it works, now we need to start the hard work.
Adjusting something like that requires a lot of time parts and materials. I suggest that people should try variations of this idea, considering around 200v output.
romerouk
Quote from: bolt link=topic=7679.msg244492#msg244492 =1276204219
I have that meter for quite a while. I have plenty high voltage sources. I have 2 neon light transformers, adjustable voltage 6kv and 9kv brand new, some other transformers 20-30kv.Plenty materials to play with.I spent lots of money(thousands) for materials over the years.I will make a video one day with all the stock I have.
