0 Members and 456 Guests are viewing this topic.
dllabarre
Quote from: Ansis on October 21, 2013, 07:55:56 AM
Hi, Keith!
Yes LONG wires are VERY IMPORTANT part of the "effects".
I do the very simple experiment: 230V main => Transformer => Rectifiere + Capacitor 10 000uF => LONG WIRES (long as possible, my was 2meters 125mm2 "soft wires") => 555 timer circuit with resistor and Zenner diode to 10 Volts with 1000uF cap to stabilize 18V power from rectifiere with 10 000uF => MOSFET driver + Induction Coil WITHOUT any BackEMF filters!!!! => At the end spark plug. We can spark "earth ground" or "minus ground". I don`t remember but I think I do like ordinary- to minus.
How do you think what was happened? These long wires starting colect voltage!!!!
My Zenner start "blow up" and Multimeter go to HIGH!!!!!
It is.
You can think about it!
Please post diagram showing all components and sizes/values.
Thanks
DonL
Grumage
Dear Verpies.
I have been quietly looking into the recent posts of GeoFusion and doing some experiments. I have mounted on a small blob of Silicone rubber cement a Ferrite half U core around which I have carefully placed a pair of 20 turn Copper coils that do not make any mechanical contact with the core. This coil is centre tapped and connected to the original Royer oscillator that GeoFusion posted here.
This design was prompted from your posts suggesting that NAR might play a large role!!
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg373340/#msg373340
I am using a pair of TIP 3055 transistors as there are no ringing diodes fitted within. Capacitor is 680nF. Frequency is 93.5 KHz.
Now this is my question. With a 24 VDC input (2 X 7 AH gel cells) I am seeing just over 200 V p/p!! Scope shot attached ( probe on X10 ). I was expecting to see around Pi x V. i.e. around 72 V p/p
Could you please explain why I am seeing such an excess of voltage than what I would normally expect.
Thank you in anticipation.
Cheers Grum.
NickZ
  Acca:
  We have tried to contact Akula concerning the working principals of his previous device.
He did not answer my e-mails, or to MenofFather, and although he did communicate with T-1000 through Skype, several times, there were no further discussions after a certain point.  That does not mean that it is still impossible to do so, at this time, but I'm just relating that an effort has been already been made to do so in the past. And since Akula may not speak English, or at least not well, this is one of the reasons that we have not continued to pursued this by non-Russian speaking people from this or the other Kapanadze's cousin thread.
  Concerning long earth wires:  Akula has shown a long ground wire, going to the saturated wet area that's about 8 to10 meters away, as well as having no earth ground, at all. It looks like both ways are possible, to have some results, at least if what we see is true. But, there may be an advantage to having a long wire, instead. Which may also be working as a type of antenna, as well as a ground. This all needs to be tested, as well as the different cores, bifilar, or not, winding methods, resonance points, feed-back methods, etz...
That is what we are trying to do.
verpies
Quote from: Grumage on October 21, 2013, 03:48:51 PM
First, I'd like to see the waveform across the primary winding.
I assume that you are powering the primary winding with this circuit. (object if that's not true)
Grumage
Quote from: verpies on October 21, 2013, 03:57:22 PM
Dear Verpies.
Thanks for your reply.
Yes that is the circuit I am using and the scope shot is looking at the primary. I have not put a secondary on as yet. The coil is 20 turns total, 10 per limb.
Cheers Grum.
