0 Members and 125 Guests are viewing this topic.
e2matrix
romerouk,  Thanks for all your work in this but please don't forget family and while the excitement may be high here don't let it put a drain on you.  Keep things balanced, stay safe and it will all work out.  Others here can do some work too as you've given enough info now for people to try this themselves.  I'm sure as you find new things you will let people know here and others will hopefully do the same.
   I'll state one more thing again as I read it a while back and I think it may be important.  The center rod or wire(s) may work best if they are not dead center but off center a bit.  I haven't seen any comment on this but I've noticed it in a number of replications and the explanation for it sounds like it will produce better results.
woopy
Quote from: broli on June 10, 2010, 05:02:02 PM
That would be boring indeed, I'm talking about connecting the high voltage of one MOT to the low voltage of the next MOT  ;D .
and so on      hoooo! Broli      do you want to explode our already so ill planet ?
Anyway  another time thanks very much to ROMERO  from UK for his fantastic work. Not so bla bla bla and showing  real results with very simple testing instrument.
Yes probably it is very incredible to get  from basic instrument   1.6 amps with 240 english volts that is to say 340 watts     and can lightsg 9  bulbs of 100 watts or let's say 900 watts     ????
but what is significant is that J L Naudin in France gets  about the same results   ho ho  and yuuuu pyyyyip!
or   these two people are connected  in order to crack us (but sincerely i don't think and why ??) or we have to realy go to work. and replicate.
so see the winding  Woopy B
and go to work and replicate
i am already vibrating from all this terrfic current howwwwwww!
be carefull
Laurent
aether22
Quote from: bolt on June 10, 2010, 12:30:08 PM
As I already explained you are all MUCH better off using DC pulses using the microwave diode before spark plug. With half wave diode only 50% power passes saving half the heat on the spark plug. Dont use Full wave bridge here its not required.  These pulses are positive respect to earth but the inrush gain from the earth are Negative pulses so its a waste any case to use AC as ALL negative pulses are wasted as total loss.
With the other refinements i mentioned you will get a cool running system using hardly any power on the MOT.
Hmmm, reading that and looking at the diagram you posted I see that this is kind of similar to a Joe Cell, the coil is charged positively thanks to the diode and cap, and the wire in the center is charged negatively, this is the same geometry and electrical polarity as a Joe Cell and various other devices, this design attracts aetheric disturbances including I guess imprinted with EM fields.
I wonder if you made a reverse version (opposite electrical polarity) you could send energy to be picked up by the other one.
I might have to give this a try, got all the gear except for the pipe.
romerouk
Quote from: woopy on June 10, 2010, 05:31:44 PM
be carefull
Laurent
I have no connection with  J L Naudin.He lives in France, I live in London - UK, foreigner not British.
I have a lot of respect for all his work. Everything he does is always well documented, tidy, showing a lot of knowledge in his work. I am very small comparing to him, many of us here are.I think that he is not trying to prove overunity with kapanadze replication, it is just showing proof of concept.Many applications on J L Naudin website are proof of concept but enough to give us a start in many directions. For J L Naudin free energy is a fact not just supposition. I am sure he has many devices built showing extra energy.
