0 Members and 111 Guests are viewing this topic.
grizli
Quote from: bolt on June 08, 2010, 08:37:25 PM
Well thanks for the circuit least we got something now which resembles KAPAGEN.
In vid shot of open box there was no diode or cap to be seen. Perhaps a slide of hand ploy and it was added later who knows. But this will pump up volts to 4kv with diodes and MOT cap and MOT are shunted design so no current limit. Connected direct to mains will be a disaster!! MUST use current control and dial up voltage supply adjusted very carefully increase from 25 volts and slowly up just to get ARC going. Too much and white molten copper and iron will fly everywhere.
I have a MOT here beside me now. NO WAY i use it like this direct to mains. Use NST or car coil instead.
Now everyone warned many times so go ahead set your house on fire or cya in heaven if you touch it! :)
than GET 400-800W mercury bulb BALLAST and put in primary with MOT
you can also use variac ..
Ballast will reduce current when mot is shortened with spark on secondary
bolt
Quote from: hartiberlin on June 10, 2010, 05:16:52 PM
Hi All,
I watched this movie from SR again
and ask myself how he is supressing the runaway with his unit ?
http://www.youtube.com/watch?v=-lhvfh3MDfc
I think this is no fake.
So how does he protect the runaway in his selflooping and selfrunning
unit ?
Regards, Stefan.
As OU exists for long time its only fake to non believers that still need a decade or two for the realization to sink in. For seasoned OU researchers as yourself the goal to OU and looping is ONLY the method not the theory.
Looping does not always mean runaway. It depends how its is looped for example lets say the o/p of KAPANGEN is looped by placing a transformer on the o/p and drop to 12 volts via FWBR now DC into a battery or for small system like 100 watts bank of caps is fine.  The circuit here could be well regulated at 13.5 volts and 20 amps which feeds an off the shelf inverter 500 watt which powers the MOT. In this case no runaway as the 13.5 volt regulator AND battery acts as a damper and controls the loop.
The other way requires a bank of caps like 500uf of  100uf each 1500 volt AC caps in order to change KAPAGEN o/p to 50hz then use large 50 amp 250 volt GDT's to keep things stable. Then loop this round to the MOT. To start the system plug in extension power cable to get caps charged for a second then unplug will self run.
Again no runaway here if GDT's keep things under control.
There is only ONE cheap way to get CLEAN power out of this thing and that is use Rotoverter technology. Anything solid state like power conditioning inverters  that can support +3Kw going to cost a fortune. Ask yourself this? When SM made the TPU the eureka moment was only the beginning NOT the end.  Its a long way from unplugging your house from the grid unless you want to destroy everything you own from super power spike.
grizli
Quote from: bolt on June 08, 2010, 11:02:15 PM
You need a few Kv to get a good spark going.  Of course if you dont feel happy working with this then stay working on 12 volt Joule THief but apart from making an LED glow longer it wont heat your house or power all your lights:)
Also Voltage = Potential Joules. If you dont put VOLTS in the ground wire you get nothing back. This system can be GREATLY enhanced using one or two more tesla stages to step up the voltage and frequency to 50kv-100kv or higher pumps more joules in the ground.
you can make high pover TC primary with 220V(ballast in series) HV diode stack and car ignition coil
grizli
Quote from: baroutologos on June 09, 2010, 06:22:59 AM
I have tried this simple experiment some years ago when i firstly saw that page. I cannot verify any claim. No surpls B-field. I saw it again yesterday in Naudin's site and i re-tried the experiment with the nails. This time i measure inductunce using an LC meter etc.
Both nails have same inductunce (mine nails) and same resistance. I regulated to go through them same amount of current by regulating it. No different effect noticed anyway. Why should be any?
Bottom line, no surplus B-field by that kind of winding at DC current.
By the way
I have used the biffilar coil extensively in cap-discharge and resonant setups. I have not notice any peculiar effect besides the huge stray capacitance that can replace the use of a capacitor, just as Tesla has claimed.
its NOT for DC..
it can only have effect if there is HF AC and that capacity between wire is significant at  that frequency
hartiberlin
Hi,
you could use this circuit to try to get a selfrunner.
Just needs an additional toggle switch and a fuse and a 60 Watts fluoresent bulb
and another 100 Watts incandescent bulb.
Also if you see, that the fluoresent bulb lights up and the circuit
gets a runaway, toggle back the switch immediately.
Regards, Stefan.
