0 Members and 113 Guests are viewing this topic.
Grumage
Quote from: Zeitmaschine on October 25, 2013, 04:20:05 PM
But »nicked from the universe« would sound surely more sophisticated and future-oriented, I think. 8)
Bank of 3-phase capacitors. For 50Hz resonance or just for fun?
Could be C1 in the drawing above.
Dear Zeitmaschine.
With regard to your recent posts, take a look at this...http://www.allaboutcircuits.com/vol_2/chpt_6/3.html
Very interesting??  :)
Cheers Grum.
Zeitmaschine
... total impedance drops to zero!
Exactly! The series impedance of the coil and C1 is zero at 50Hz but because there should be an energy input from ground due to the high voltage resonance of the same coil we then should have a power source (the series resonant circuit) with zero internal resistance (meaning unlimited energy in theory).
Except it does not work, then we will have just a nice smoke cloud (as usual). ::)
But at least this setup complies with »so simple you'll laugh«. ;D
Actually I think this could be an impedance transformer (converter) of some kind. The input (HV) impedance is infinite (not even a closed circuit) whereas the output impedance is zero (at 50Hz).
Haan
Quote from: Grumage on October 25, 2013, 04:56:29 PM
Dear Zeitmaschine.
Interesting reference article.
It indicates that L and C should be in series.
Haan
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/dlattach/attach/129071/
Zeitmaschine,
looking at the wiring for the capacitors on the bottom-right of the picture (you provided), it appears that there's 2 capacitors wired in series (labelled I and II).
With 12 capacitors in total, if one assume all of the capacitors are wired in pairs, that makes 6 sets of capacitors in total.
ie. 2 sets per phase, with possibly one set used on the primary side & one on the secondary.
Do you agree?.
baroutologos
@ above,
Thinking about Kapanadze device again and stimulated by the above photo, in a purely speculative way, I will speak having two conditions in mind.
1) All the current supplied to the load, 50 Hz or so, is equal with the current oscillating in the ground wire.
2) The current oscillating back and forth, via one wire, is stored to a internal capacitance.
Said that, have you ever thought about the kind of capacitance we are talking about for such a 5Kw device? Let me start talking otherwise..
a) A Typical Tesla coil LC circuit with specifics (powering a load) : topload capacitance of 100pf, 20 Kv voltage, 125Khz frequency, it can max output over a suitable resistance some 5Kw and having a ground current of approximately 0.5amp according my calculations.
(note we are talking about energy transfer not energy creation in this case)
b) Kapanadze's device that will output 5kw working at 50 Hz will need some 800+ uf alternating at 360v p-p. Of course with a frequency of 400Hz will be needed 1/8 of that capacitance. In both cases ground wire current will be around 28 amps. (This matches with some indications)
In such case, HUGE capacitances are involved not to mention again the problem with charging such capacitances via one wire ( one terminal oscillator) in a relative low frequency!! :D
