0 Members and 180 Guests are viewing this topic.
Zeitmaschine
Quote from: Haan on October 25, 2013, 11:38:53 PM
looking at the wiring for the capacitors on the bottom-right of the picture (you provided), it appears that there's 2 capacitors wired in series (labelled I and II).
But not connected as it seems because one wire is cut. And that indicates that a precise capacitance is needed here (to get resonance).
Quote from: baroutologos on October 26, 2013, 03:24:04 AM
2) The current oscillating back and forth, via one wire, is stored to a internal capacitance.
Why not to an internal inductance? A resonant LC circuit needs a capacitance and an inductance. Therefore the energy can be stored in the magnetic field. How do we calculate that?
Regards :)
Grumage
Quote from: Haan on October 25, 2013, 11:13:38 PM
Interesting reference article.
It indicates that L and C should be in series.
Dear Haan.
Also note that the same formula for calculating resonance can be used for "SIMPLE" series or parallel circuits!! :)
Cheers Grum.
Haan
Quote from: Zeitmaschine on October 26, 2013, 05:42:30 AM
It only appears to be cut because of the low image resolution resulting in pixelation.
I thought you would comment on the 6 sets of capacitors observed ...
Zeitmaschine
I see this as a clear cut. These two capacitors are connected in series and not 3-phase. So they are apparently not for the same purpose like the others (if they where connected at all). The white wire on the right side goes to a different direction (upwards) than the other white wires. Maybe they are for the second resonance with higher frequency thus the series connection which lowers the capacitance.
Question: When the device is a 3-phase one then it works most likely with a 3-phase transformer. But does each phase then need a separated high voltage input or just one high voltage input (and therefore just one high voltage resonance) for all 3 phases together?
baroutologos
Regards :)
SImply because internal inductance poses no problem. Its easily made. Internal capacitance of huge figures for a single terminal oscillator is an impossibility!
