0 Members and 113 Guests are viewing this topic.
stivep
Quote from: Zeitmaschine on October 25, 2013, 05:25:53 PM
... total impedance drops to zero!
Exactly! The series impedance of the coil and C1 is zero at 50Hz but because there should be an energy input from ground due to the high voltage resonance of the same coil we then should have a power source (the series resonant circuit) with zero internal resistance (meaning unlimited energy in theory).
Except it does not work, then we will have just a nice smoke cloud (as usual). ::)
But at least this setup complies with »so simple you'll laugh«. ;D
Actually I think this could be an impedance transformer (converter) of some kind. The input (HV) impedance is infinite (not even a closed circuit) whereas the output impedance is zero (at 50Hz).
here what it is:
  in any circuit you have capacitive reactance, iductive reactance  and resistivity of the physical material used.
at series resonant circuit
the best explanation  for you would be
http://www.youtube.com/watch?v=hqhV50852jA
yes in series resonance  in the frequency of resonance circuit act as short heaving only pure resistive character  showing resistive reaction and acting as dissipative load or part of the load of total  load if any.
but the problem is that in any series circuit or  parallel circuit you have presence of any combination of circuits at the same time.THAT IS DUE TO ITS OWN
IMPURITIES IN CHARACTER OF THE CIRCUIT.
For example you can have HP 4194A  impedance gain  phase analyzer that will give you for any circuit
series
or
parallel
or
serious-paralel
properties of the same circuit at the same  resonance  frequency.
So if majority of the circuit is series for that  particular frequency as character of the circuit
(a part from  the fact that  in reality there is coil and  there is  capacitor connected in series)
is in series resonance there still will be presence of properties of other  forms for resonance configuration  but NOT IN RESONANCE IN THAT TIME yet still present and still affecting the  circuit.
Wesley
NickZ
  I would also tend to agree that that wire on the left bottom capacitor has been cut, and is NOT connected.
  Here is a slightly enhanced version of the picture. Look again...
conico
Mr Semenihin, the diagram has errors.
What is the role of the mosfet?
Zeitmaschine
Quote from: stivep on October 26, 2013, 11:19:56 AM
Is this good or is this bad? ???
The apparent resistance of the 50Hz series LC circuit goes to zero at resonance. Normally this would mean a short circuit and hence zero voltage. But since the coil L of the LC circuit is a power source by itself (due to the 100KHz resonance of the high voltage input) it could be a whole different picture. The coil L is in parallel resonance with the second capacitor at high(er) frequency. So there should be a voltage across that coil L although from the 50Hz point of view the apparent resistance is zero (or near zero). But a (50Hz) voltage source with low (near zero) internal resistance can provide a lot of power. Unfortunately this is not a typical power source (like a power generator) so I'm not sure about that.
Are there any references describing a LC circuit wherein L itself acts as a power source?
Acca
   To:    baroutologos   Wow it looks like you do not add any thing of value to any of the posts like just in the  examples below !! just from last few posts and you have alienated stupify12... Say something GOOD ... negative is bad !!! especially here .. as this forum for NEW ideas !!! go elsewhere if  you are NEGATIVE  detractor !!    Yah !! this is my OPINION !! and I have my right here to post this also !!    and  I been here since page 150 on this thread !!
Quotes from "baroutologos"
"I will reftrain from theorizing"
"I have run royers with no series inductance at all, but with seriously impaired efficiency"
"There is not a single instance that a Tesla bifilar coil has shown any extraordinary property"
"Have any fresh evidence to show or just you speak in the merit of theorizing?"
"typical behavior of a know it all freshstarter..
The point is not to tell me i am wrong. The point is to show to me and the forum with facts & figures, photos and videos."
"If that are too much for you and cannot tolerate some mild critique arisen from your statements.. then See you around"
"Internal capacitance of huge figures for a single terminal oscillator is an impossibility!"
"For vintage purposes, having almost a year or so, today coincided to review kapanadze's original video."
"It gave me the impression, the whole device is revolving around a thick black ground cable that is connected firstly to the water pipe and afterwards with diminishing results (?) to the buried radiator.
Excepting the possibility this is a illusion, all it has to do with ground. Heavily relying on the ground. No high amperage from ground, no fun."
Acca ....[/font]
