0 Members and 572 Guests are viewing this topic.
Quote from: Haan on October 26, 2013, 09:16:03 PM
"Increased capacitance" ... interesting.
Tesla said that bifilar windings have less inductance, not increased capacitance.
Oh please.
From the patent #512,340:
In order to attain my object and to properly increase the capacity of any given coil, I wind it in such way as to secure a greater difference of potential between its adjacent turns or convolutions, and since the energy stored in the coil considering - the latter as a condenser, is proportionate to the square of the potential difference between its adjacent convolutions, it is evident that I may in this way secure by a proper disposition of these convolutions a greatly increased capacity for a given increase in potential difference between the turns.
I have illustrated diagrammatically in the accompanying drawings the general nature of the plan which I adopt for carrying out this invention.
NickZ
  Good points you all.
  quote from Verpies:
  " In other words, proof for nonexistence cannot exist in principle because lack of proof for existence is not a proof for nonexistence."
  It would be good to keep that in mind concerning our discussions of the "Aether",  as well.
Cap-Z-ro
...and a lack of proof does not necessarily constitute a lack of troof.
stivep
Quote from: Zeitmaschine on October 26, 2013, 03:25:25 PM
Is this good or is this bad? ???
The apparent resistance of the 50Hz series LC circuit goes to zero at resonance. Normally this would mean a short circuit and hence zero voltage. But since the coil L of the LC circuit is a power source by itself (due to the 100KHz resonance of the high voltage input) it could be a whole different picture. The coil L is in parallel resonance with the second capacitor at high(er) frequency. So there should be a voltage across that coil L although from the 50Hz point of view the apparent resistance is zero (or near zero). But a (50Hz) voltage source with low (near zero) internal resistance can provide a lot of power. Unfortunately this is not a typical power source (like a power generator) so I'm not sure about that.
Are there any references describing a LC circuit wherein L itself acts as a power source?
Excellent
on the schematic attached :
You actually show coil with its own capacitive factor known as capacitive reactance.( the capacitor can be just)
the thicker the wire( say flat wire of aluminium foil the higher is interwinding  capacitance
but even  straight  piece of 10 cm of wire at any gauge wil still be resonant circuit of its own resonant frequency  with all of the roperties of series and pararel and dual factors of that circuit.
Another words It can resonate at  minimum at two   different frequencies one for parallel and one for  series
interesting, is not that?
Also circuit you have shown my friend  will act on two or more different resonat  frequencies at minimum,
and mixed one at the same time!!! ....................if spark is implemented as source of spectrum
of frequencies
Pick of maximum of amplitude for  each  one depends from maximum of amplitude of driving frequency of spark generator.
spark can be replaced by  withe  noise generator or by any noise generator including HV coil from   your car :) ignition system
Interesting would be in here how cancellation of different  resonances behavior , builds sort of logic  system just by using copper of the coil only or by combination of additional capacitive reactance from additional capacitors.
But remember:
usually (but not always) introduction of capacitor to the circuit lowers down the resonant  frequency.
However
whenever we have  capacitive character of resonant circuit (or part of  resonanant structure - acting at tis moment as, single one for purpose of  analysis)
that means that frequency of circuit or frequency of generator is below( just little below) the frequency  that circuit is tuned to.
than:
we have high  voltage sometime  thousands of volts even if the circuit is not driven by HV generator. and current is low
but
if we are above the frequency the  circuit is tuned to than we have inductive character where current  is high and voltage is low.
so if we have  say spark or withe noise in complicated number of connected resonance circuits than we may build logic "that  is sort of similar to TTL."
Yet drastically better as deals with electrostatic field as well. Well say electrostatic forces - for skeptics :)
that might explain "magics" of coil winding and coil  shape ....................... and coil shape in  spacial 3 D space
.............. and   beauty of things just wire can do..
Wesley
SeaMonkey
Quote from: Nikola Tesla provided by Tinsel Koala
It must not be forgotten that N. Tesla was a bit
of a prestidigitator and his writings and commentary
relating to his work were often vastly hyperbolic.
His knowledge and understanding of things electrical
was quite advanced for his time but if he were alive
today he'd no doubt make numerous changes to his
prior opinings.  Many of his speculations were flat
wrong.
The inter-winding capacitance of a coil can be
significantly increased with flat or ribbon
conductors.
