0 Members and 268 Guests are viewing this topic.
00
Quote from: Zeitmaschine on October 27, 2013, 05:50:20 PM
If he can't build a self-runner then something with these measurements must be wrong.
According to Tariel - many people achieve in their experiments Free Energy, but they don't understand how to reduce frequency and voltage.
As we can see, TK's lamps are connected by means of a thick orange wire leading into the tin can. So what is the component connected to that wire within the tin can?
1) A coil?
But a coil wound on an iron core which can output 220V at 50Hz at 24A would surely not fit into that tin can.
2) A capacitor?
A relatively small capacitor can provide a hight current, but only for a brief moment, then it needs to be recharged. So how to recharge that capacitor continuously? If this capacitor is part of a resonant LC circuit then there could be a certain chance the coil L in that circuit can recharge this capacitor continuously by means of high frequency (so the coil can be kept small) if this coil is the secondary coil of a transformer which primary coil is an open high voltage circuit drawing energy from the environment.
In theory.
yes its capacitor in the tin box. kapanadze source can be understood by replications of chubinidze and replication done by RED. input is done by inverter type oscillator using two transistors. there are two ways one is using pulsed dc spark and other is alternating hv ac spark. the spark can be avoided by using igbts switching back and forth as done by akula. but much protection is required in sparkless version as they blow up due to back emf pulses. these are called radiant spikes and can be had with a coil inside the pulsed tube. the magic is that when we pulse with hv dc spark from outside coil of thick copper wire as shown in kapanadze setup the coil inside that copper coil exhibits alternating current. one from inductive effect and other from back emf so we have ac in the inside coil. more coils wound  coil inside a coil will give more output.
radiant energy is quite reverse from our hot electricity.
wot we call high resistance  becomes  low resistance for radiant
we need core for hot electricity radiant dont need core
thick wire low resistance in hot one where as thin wire low resistance in radiant.
people dont understand this thats why they fail in replications.
find out more on earth energy from ground as shown by kdkinen. ground response is same as radiant spikes.
resonance works here also in kapanadze and its not between primary and secondary its between back emf and ground  and spark just keeps this process running. energy comes from back emf and ground energy. spark just play as catalyst and must not decay else no resonance between ground and back emf in coils.
and without ground you wont get power.
ps: quote
"All truth passes through three stages. First, it is ridiculed, second it is violently opposed, and third, it is accepted as self-evident."   Arthur Schopenhauer, German philosopher, 1788 - 1860.
00
ARMCORTEX
OO thx you for coming back.
I have saved all your posts here I consider them important.
baroutologos
Quote from: a.king21 on October 27, 2013, 10:26:06 PM
Baratoulogos:  I think TinselKoala would disagree with you as I would.
https://www.youtube.com/watch?v=mvb39SwTXBE
I have seen this video in the past and thought about this. honestly.. i cannot  say i am intrigued. This is what i think anyways. The transmitting LC (hence L+C) with a given power will produce some EMF in the vicinity. Either the plain coil or the biffilar should have similar (assumption) transmitting properties. (assuming the primary cap is a **1000pf or so and the biffilar's capacitane even less say 30-100pf for those windings? i cannot know for sure)
The great difference lies in the receiving part. If the receiver coil share same inductance with biffilar but nowhere near capacitance then the same impressed EMF from primary, it is attenuated in the biffilar due to capacitance and not running it at its resonance frequency. This is what i see.
ps:I have not done the experiment, i may be wrong :D
Haan
It would be interesting to compare to the results shown in the video to one using a Tesla bifilar coil as transmitter *and* receiver.
Ansis
Quote from: 00 on October 28, 2013, 01:12:12 AM
00
Bravo! Applause!
P.S. I think the same! Tesla Bifilar coil is the CAPACITOR inside. Look at my "probably Kapanadze picture". Inside the coil there are 10 Tesla Bifilars. Yes, Zeitmachine do logical explanations about "thick" wires- there are VERY MUCH MORE ELECTRONS, but in "dead" form! BackEMF, Tesla Bifilar coils, FAT WIRES,FREE ELECTRONS of Earth do the JOB! Yes 24 Amperes are in the THICK WIRE chain! This is 20 meters long thick wire chain and between there are? We must resolve it! Dear friends, there we no need to spark much, just very little! Thank you all!
