0 Members and 199 Guests are viewing this topic.
Quote from: bolt on June 10, 2010, 06:28:11 PM
The other way requires a bank of  caps like 500uf of  100uf each 1500 volt AC caps in order to change  KAPAGEN o/p to 50hz then use large 50 amp 250 volt GDT's to keep things  stable. Then loop this round to the MOT. To start the system plug in  extension power cable to get caps charged for a second then unplug will  self run.
Why the heck do you need to convert it back to 50Hz-60Hz if you want to loop it. If you loop the raw output through a mot and some safety like a spark gap in parallel you get exactly the frequency the setup likes to work with. I'm inspired to start experimenting myself with this but I won't run around the bush, my main goal will be a closed loop and nothing else.
bolt
Quote from: broli on June 10, 2010, 06:37:30 PM
Because the KAPAGEN o/p is Khz NOT 50hz and the MOT will NOT work on HF. The MOT is already a really shit design where core is fully saturated efficiency is like 55% at 50hz. At 200Hz already lost half as much power again. If you scope the o/p its just total MUSH from the spark gap thats why the bulbs are flickering all over the places and arcing inside due to HF.
grizli
Quote from: hartiberlin on June 09, 2010, 05:07:40 PM
If you look again at these 2 videos,
it makes sense to have also additionally to the 6 turn
output coil the loop going through the center of the coils,
cause this seems to add additional induction energy to the system.
Have a look again to these 2 videos for reference:
http://www.youtube.com/watch?v=eH2TWPJiwEA
http://www.youtube.com/watch?v=1rPyc_l-TVQ
make tranlation of whats he doing there ?
I mean any data about freq, voltage, etc if possible
Thank you
This seems like this metal rod inside makes loop and 90 degree to original magnet field
Quote from: bolt on June 10, 2010, 06:55:00 PM
Oh I didn't think of that I stand corrected.
Then the question is....is it cheaper to use a core that can handle the power and frequency or is it cheaper to get an high voltage FWBR, an inverter and a car battery.
woopy
Hi Romero  uk
What i meant is that you are not alone with your results  as JL naudin seems to get something really near to your's with  the Kapagen.
Of course as these result are really incredible , and as you are ready to answer , we will bomb you with a lot of questions.
That is why it is very important that you answer the basic questions,  so every body can replicate as soon as possible.
and than you will be partially relaxed from our hunger.
And i thank you very much because   you already did it. As you already gave us the  necessary stuff to replicate
- the winding direction  (woopy  B )
- turns number of each coil with estimated diameter of wire diameter (4 mmn copper)
- diameter of the plastic tubing
- 3 videos of how it works
- a lot of explanations about the MOt without or with diode and cap to rectify the current
and all this in 1 day
so no excuse to any body to not be able to replicate
I dare to declare you a hero of this forum and wish you the best night
Laurent
