0 Members and 265 Guests are viewing this topic.
captainkt
@Ansis, I am sure this is right direction.
Keith
captainkt
@all, one of Kapanadze vids shows on workbench a thick stranded cable attached to the chuck of a power drill, looks as if he was trying to straighten out the twist during manufacture to make a sort of Litz wire ? Certainly normally a strange thing to do.
Keith
Hoppy
Quote from: captainkt on October 28, 2013, 05:56:53 AM
Keith
Maybe to tightly twist the strands from the ten separate and insulated multi-strand wires in the cable if same cable as that in Ansis's 'probably Kapanadze picture'??
Whilst on the subject of wire strands, a thought occurred to me that in the 'green box' video, we see a guy twisting the strands of a long 'earth' wire onto the strands of the wire connected to the buried radiator. The other earth wire is connected to the water pipe. Now, say at an appropriate point in the demo, the earth wire connected to the radiator was replaced by a grid supply. In this situation there would be a path from grid 'live' to earth ground at the water pipe, passing right through Kapanadze's device. How convenient is that! My suspicion is that the live feed was coming from the house on a wire that was hanging over the balustrade - ref the 'transparent box video' where this wire can be glimpsed (see clip below)  and the area below the canopy near where the wire drops, was guarded by a couple of TK's heavies!
captainkt
@Hoppy, Only problem is that I thought everyone came to the same conclusion that the radiator did not provide a good enough earth for gen to work properly so wires were changed to water pipe and in fact radiator does not get used at all. Only one earth required. To scam this two wires would be needed and in front of press and investers I dont think so. Even if water pipe was live then there is still no return path. With voltages and high current involved someone could could get a nasty shock at least, and if camera present what a risk of embarrassment !
Keith
Hoppy
Quote from: captainkt on October 28, 2013, 07:16:30 AM
Keith
That's what I originally thought but I'm not sure as I can't see if and when it got disconnected. I've probably missed it on the video through too much eyeballing!  ;D Maybe someone can direct me to the point where the radiator is disconnected and the wire pulled back to put me right on this.
With regards to the safety issue using mains, remember the bit where the tester is pulled away from the water pipe whilst trying to take a measurement. Maybe this was because the pipe was about to be energised.  :o As far as the device itself is concerned, the switch on the green box would disconnect any supply to the bare wire terminated lamps.
