baroutologos
@hey hoppy,
for conversation's shake, i have the impression that the water pipe is a good ground and the radiator a poor ground. I think also they measure a voltage difference from radiator to water pipe some... 6 volts? And one asks is that milivolts? No volts the other replies. Of course i know nothing of Georgian but this is what understood.
Anyway, it gives me not the impression 2 grounds were connected simultaneously. Note the video is edited and we do not know what they have actually did. And another issue is that, if you go "live" the radiator and return the water pipe, being in the wet ground buried (radiator) will make a heavy short i would say.
Of course this all are speculations since Kapandaze and his friends left the working of his device in dark, having us to explain things in UFOlogy terms! :D
captainkt
@Hoppy, interesting you just brought up another problem with fake gen, power from mains would have to be isolated immediately from green box switch, this would be hard to do, via radio link maybe.
I now think now that it is pulsed HV into 10 bifilar coils to earth via litz cables terminating in one connection point volts remain the same amplifying the current by 10 times. Similar to Simon Mark theory.
Keith
Hoppy
Quote from: baroutologos on October 28, 2013, 08:53:05 AM
@hey hoppy,
:D
I'm suggesting that the device and lamp array are the load between the disconnected radiator cable reconnected to the grid 'live' and the water pipe ground connection.
Hoppy
Quote from: captainkt on October 28, 2013, 09:08:22 AM
Keith
Captain,
Or by phone link by the guy standing next to the bearded guy. Watch these two very carefully throughout the green box video. The switch on the device would just need to switch-off the supply to the lamp array. The main grid connection would only need to be made when the demo starts and finishes. TK has a couple of heavies posted in the garden in case anyone goes a wandering! The magician relies on the audiences collective eye staying enthralled and focussed on the trick, not wandering around the stage looking for clues!
skywalker66
Quote from: Zeitmaschine on October 27, 2013, 05:50:20 PM
As we can see, TK's lamps are connected by means of a thick orange wire leading into the tin can. So what is the component connected to that wire within the tin can?
1) A coil?
But a coil wound on an iron core which can output 220V at 50Hz at 24A would surely not fit into that tin can.
2) A capacitor?
A relatively small capacitor can provide a hight current, but only for a brief moment, then it needs to be recharged. So how to recharge that capacitor continuously? If this capacitor is part of a resonant LC circuit then there could be a certain chance the coil L in that circuit can recharge this capacitor continuously by means of high frequency (so the coil can be kept small) if this coil is the secondary coil of a transformer which primary coil is an open high voltage circuit drawing energy from the environment.
In theory.
Hi !
Can you think that the high amps not come out from tin box, but are build up in that big external coil formed from orange coil , white coil and heavy cooper pipe as a combination of radiant negative HV (source of electrons) superimposed upon a couple of opposing magnetic field formed by orange coil (H1) and white coil (H2)?
