0 Members and 504 Guests are viewing this topic.
verpies
Quote from: captainkt on October 28, 2013, 07:16:30 AM
To scam this two wires would be needed and in front of press and investors I dont think so. Even if water pipe was live then there is still no return path.
But you recently stated that he was making a Litz wire and such wire is composed of many separately isolated wires ...many more than two.
Quote from: captainkt on October 28, 2013, 05:56:53 AM
one of Kapanadze vids shows on workbench a thick stranded cable attached to the chuck of a power drill, looks as if he was trying to straighten out the twist during manufacture to make a sort of Litz wire ? Certainly normally a strange thing to do.
Seems quite normal if one (or several) of the Litz cable strands provide the return path.
Zeitmaschine
Quote from: Hoppy on October 28, 2013, 09:13:52 AM
I'm suggesting that the device and lamp array are the load between the disconnected radiator cable reconnected to the grid 'live' and the water pipe ground connection.
Why connecting to the grid 'live' given the fact that we are living between the two plates of a highly charged capacitor? :D
Quote from: skywalker66 on October 28, 2013, 09:27:25 AM
Hi !
Can you think that the high amps not come out from tin box, but are build up in that big external coil formed from orange coil , white coil and heavy cooper pipe as a combination of radiant negative HV (source of electrons) superimposed upon a couple of opposing magnetic field formed by orange coil (H1) and white coil (H2)?
If that big external coil would contribute to the generation of amps then there would have been a successful replication of that coil a long time ago because it is right in front of the camera. Actually I think that blue and orange coil is just a decoy. Since the main parts are all hidden in the tin can (except the DC power supply) TK had to show something. An (almost) empty table would not look so nice in the video. ::)
And now I have to think further about resonant LC circuits, operating in non-standard mode. One thought: When the connected load does not necessarily need a frequency of 50Hz (incandescent lamp or heater) then any (resonant) frequency should do it.
captainkt
@verpies, It can be seen quite clearly that all wires are twisted tightly around the water pipe with a pair of pliers, no separation at all. I am a sparks by trade but could not pull off a stunt like the one you suggest especially in front of audience , sorry.
Keith
NickZ
  Guys:
  Tinselkoala's video does not prove that it can light a string of 1k to 3k incandescent bulbs, like TK. The indicator light is flickering, it's not steady, as well as the spark.
It only proves that there is bigger spark coming out of the bifilar coil, as compared to the regular spiral coil.
  Chubinidze's device has a very small, weak, and silent spark, so does Akulas, so those sparks are not the source of where the actual power is coming from, they may only be used as the coil activator. Although, no SG may actually be needed like in Akula's first video. And their bulbs don't flicker, either, nor do they shock, at all. This is proof of cold electricity possibly magnetic, and not hot normal electrical current. Or not???
  This is my version of the GeoFusion replication, for those that don't view the Daly thread.  I'm still very much at the testing and further testing and modifications stage.
It does NOT shock, at all, from any part of the device. I can dimly light a 100 watt bulb from 12v 500mA, as you know would be impossible normally.
The picture below is showing it lighting two 50 watt bulbs, using a 12v, 4.5 aH battery, the only heat is coming out of the bulb, although the Fets do get hot after a while, still.
  I have not been able to place a cooling fan on the Royer oscillator (twin IRF 620) circuit, as the 12v pc fan won't spin when connected directly, to the 12 battery.
  Any ideas on how to get the fan to work, is welcome.
The main difference of this circuit, compared to my previous Joule Ringer HV type circuits is possibly that this is cold electricity, giving no shocks, nor needing HV, or HF to work.
Hoppy
Quote from: Zeitmaschine on October 28, 2013, 10:05:45 AM
Agreed, except the AC power supply  ;D
