0 Members and 107 Guests are viewing this topic.
Zeitmaschine
Quote from: NickZ on October 28, 2013, 11:26:44 AM
Chubinidze's device has a very small, weak, and silent spark, so does Akulas, so those sparks are not the source of where the actual power is coming from, they may only be used as the coil activator.
Or as a smoke screen.
And their bulbs don't flicker, either, nor do they shock, at all. This is proof of cold electricity possibly magnetic, and not hot normal electrical current. Or not???
Can a 3-phase motor run on cold electricity? ???
Wikipedia: »The charge flows back and forth between the plates of the capacitor, through the inductor. The energy oscillates back and forth between the capacitor and the inductor until (if not replenished by power from an external circuit) internal resistance makes the oscillations die out.«
At one moment all the energy of the oscillation is stored in the capacitor, the coil is empty, so it can be easily refilled with energy from the outside. That means during the next oscillation cycle this additional energy flows to the capacitor making room in the coil for the next refill from the outside (Earth's electric field) keeping the oscillation going (with a little bit of luck).
Quote from: Hoppy on October 28, 2013, 01:29:34 PM
Agreed, except the AC power supply  ;D
There will be a day, not far away, when one talks about connecting to mains, he will not refer to the power grid, but connecting to the Earth's electric field.
einestages :P
skywalker66
Quote from: Zeitmaschine on October 28, 2013, 10:05:45 AM
  Why connecting to the grid 'live' given the fact that we are living between the two plates of a highly charged capacitor? :D
If that big external coil would contribute to the generation of amps then there would have been a successful replication of that coil a long time ago because it is right in front of the camera. Actually I think that blue and orange coil is just a decoy. Since the main parts are all hidden in the tin can (except the DC power supply) TK had to show something. An (almost) empty table would not look so nice in the video. ::)
And now I have to think further about resonant LC circuits, operating in non-standard mode. One thought: When the connected load does not necessarily need a frequency of 50Hz (incandescent lamp or heater) then any (resonant) frequency should do it.
Well, we must see the BIG picture, all Kapanadze devices display large external coils with heavy wire, even others who build working devices like Akula, Cibinidze, etc, display some sort of heavy coils and electrostatic field in plain view, I strongly doubdt that all are just for fun. We must not dismiss  just yet as simple decoy, IMO they have a key role in device's function. To spend a lot of money on heavy copper wire just for distraction it seems to me a stupidity, isn't it?  If we look for a common denomitor for all such devices, this is some LARGE COIL in ELECTROSTATIC GRADIEND, and a single ground connection. That sound like a electron pump.
Let assume we remove external coil assembly from 2004 video, then 5kW power generated in that tiny tin box, well with alien tech maybe (some sort of protomatter convertor, antimatter reactor, pick one  ;) ) , but not with Kapanadze's tech. Think about that...
forest
Watching that thread I ask myself : what is missing ?  Why we can't find the truth ? I see many people with good ideas and a few with not so good intentions, maybe that's the reason ? Disinfo ? If you investigate Kapanadze videos few times more using the proper SCIENTIFIC methods and a clear mind you would find the answer for many questions. First formulate the question then find the answer, it's all there.
I don't know why Hoppy is posting all that incorrect informations , which surely would throw some people in wrong direction because simple analysis of green box video give you SURE answer that device was connected in the same time  to ONE ground only  (the pipe or radiator) and radiator would only allow light of one or two bulbs.
a.king21
Quote from: skywalker66 on October 28, 2013, 03:20:19 PM
Not only that but Kapanadze uses HV wire in his bifilar output coils which is very expensive.
Zeitmaschine
Thinking about that, here is TK's 2KW Device with just a tiny coil looking completely different from the big 2004 coil. Hence if the shape and size of that coil does obviously not matter (as it seems) then maybe the coil does not matter as a whole (except it looks nice).
And I guess, aliens have this tech already ...
