0 Members and 504 Guests are viewing this topic.
Hoppy
Quote from: forest on October 28, 2013, 03:26:48 PM
I don't know why Hoppy is posting all that incorrect informations , which surely would throw some people in wrong direction because simple analysis of green box video give you SURE answer that device was connected in the same time  to ONE ground only  (the pipe or radiator) and radiator would only allow light of one or two bulbs.
I'm not trying to throw people in the wrong direction, that's what I am sure Kapanadze is doing!!
Yes, one ground only at a time but the real puzzle is where was the 'live' feed connected. The question that niggles me, is why would TK start off with an old rusty radiator as an earth when he had a better earth at the water pipe. Surely he would have established the best earth before the demo?? I think the radiator may have been some kind of decoy but I'm open minded as to how the 'live' feed was supplied to the device.
skywalker66
Quote from: a.king21 on October 28, 2013, 03:38:18 PM
Not only that but Kapanadze uses HV wire in his bifilar output coils which is very expensive.
It's not quite bifilar as per se, and if you wish is a sort af assimetric bifilar. The idea is there are two layers, two coils witch form 2 opposed magnetic field. Something like a double vortex as I see things. And yes, the coils must have good insulation to prevent forming arching from HV to that coils. IMO the all mechanism is to apply a strong electrostatic gradient upon strong couple of opposing magnetic field at 90 degree. But is just my view, an analisys if you wish.
skywalker66
Quote from: Zeitmaschine on October 28, 2013, 03:55:26 PM
Thinking about that, here is TK's 2KW Device with just a tiny coil looking completely different from the big 2004 coil. Hence if the shape and size of that coil does obviously not matter (as it seems) then maybe the coil does not matter as a whole (except it looks nice).
And I guess, aliens have this tech already ...
To many black&white boxes there. I wonder what's inside? The coils is present here also, smaller indeed, but I pressume that device working at a higher frequency than 2004 dev. If you ask me I see same pattern as in 2004, do you? Two heavy insulated coils is connected to load, and underneath a tiny magnetic wire for electrostatis purposes.
Aliens don't come just so far burning oil or coal, or did they?  :)
Zeitmaschine
Quote from: skywalker66 on October 28, 2013, 04:40:22 PM
Knowing Kapanadze, three of four boxes are empty. 8)
Can't help myself -this has been discussed already somewhere a few hundred pages ago-  but a simple crystal radio looks still strikingly similar to that what is suspected to be in TK's tin can.
We have here a ground and an antenna and an LC circuit tuned to resonance. The only thing missing here is the high voltage, but of course a crystal radio can't give out a few kilowatts of power.
Building a radio in 10 minutes
So what is it all about? The ground and the antenna of the crystal radio connects to the Earth's electric field. That electric field is disturbed by the radio waves coming from the radio station. Hence the output energy of that crystal radio is sufficient to drive a small ear piece. And I doubt that the energy for this ear piece is coming solely from the transmitter. The disturbed electric field generates additional energy.
The radio station disturbs the Earth's electric field by sending out radio waves. Kapanadze disturbs the Earth's electric field (creating vibrations in it) with high voltage. That's one difference. Since the disturbance by high voltage is greater the output energy is also greater.
The second difference is that the radio station modulates the high frequency of the transmitted radio waves with low frequency, so the ear piece can generate sound waves. Since the high voltage is not modulated Kapanadze uses for this a 50Hz inverter to bring down the high frequency of the high voltage.
Therefore could it be that the Kapanadze device is simply a derivative of a crystal radio? So simple you'll laugh? :D
a.king21
Quote from: Hoppy on October 28, 2013, 04:15:04 PM
If you read the transcript of the 2004 video you will see that even with investors present Tariel still liked to experiment. In the green box video, he knew his system worked so he thought"why not?". It shows supreme confidence. Then when the radiator didn't give him the results, he changed to the tried and tested buried water pipes.
I've experimented with sending mains through a ground rod and can tell you this: it sometimes takes time for the ground to find a return path. I think if TK had the time he would have waited for his system to kick in, but with cameras and the press present he had to produce his show.
The crystal set is an important analogy, because it shows a ground amplification effect.
Just my 2 cents worth.
