0 Members and 464 Guests are viewing this topic.
captainkt
@Zeit, then being practical do we pulse with same source/frequency or completely different one, can we pulse down the same Earth or point in wire, do we amplify return from same point. Also with all the excess grid power and all the dumping into the Earth from wind turbines plus everything else why could we not tune to these, because if what you suggest there are already thousands of transmitters working at this moment pumping signals/sparks/frequencies into the ground/Earth from all directions and all countries without us having to send any of our own.
  Found a simple way to check for good grounding, use grid power to bulb to the earth point I have put in and compare brightness of another bulb with grid to bulb to neutral of grid. It might not be very scientific but it is  a quick comparison, I have been experimenting and at times I have had what I thought was a good grounding but bulb only half bright when checked like this.
Keith
stupify12
Quote from: Utopia Now on October 28, 2013, 08:39:47 PM
Hello Wesley Stive P
It would be Wonderful if you could translate this video ...  Free Energy Selfrunning Device from ikako chubinidze Youtube channel with circuit diagrams.
http://www.youtube.com/watch?v=5nxKqfkkndw&feature=c4-overview&list=UUbcaIfmxRZhnnYVqG81kCZg
I am very happy with the other translations you allready  did .  I appreciate very much your work ... and  Spirit :)
Utopia Now            http://prezi.com/fiwgtl78it85/donz-device/
The only ingredients on the Tesla Transformer you haven't successfully investigated is why all the people who successfully replicated the Kapanadze has a thin sheet/plates of Irons on the Main Coil. A Close Magnetic Circuit composed of Iron Wires Close Circuit and Iron Plates Close loop also.?
Look for the Iron Plates or Iron Wires configure in a Close Magnetic Circuit. That is the real secret here to produce a induced voltage on the Secondary with a Phase Shift 90degrees. The Close Magnetic Circuit is the reason of the lag or delay of the Phase Shift.
Look for other person with a successful replication and look for the Iron Wires or Iron Plates underneath the separated Coils= Bifilar CW + CCW?
Post all the pictures of the Iron Plates or Iron Wires shots on their Tesla Coil. ;D ;D I think any metal would do as long as it function as CLOSE MAGNETIC CIRCUIT.
Just my 2 cents ;D ;D
Meow ;D ;D
Zeitmaschine
For your imagination: This is all about having a charged capacitor (which undoubtedly contains usable energy) but having only access to one plate (negative ground). How to get grip on the energy stored in that capacitor?
There should be a (simple) way, shouldn't it?
And I surely do like the expression »galactic power line« on that website. ;D
Hoppy
Quote from: a.king21 on October 28, 2013, 06:12:46 PM
If you read the transcript of the 2004 video you will see that even with investors present Tariel still liked to experiment. In the green box video, he knew his system worked so he thought"why not?". It shows supreme confidence. Then when the radiator didn't give him the results, he changed to the tried and tested buried water pipes.
Yes, this does show confidence that his system works and I also realise I was wrong about the 'live' feed being switched onto the radiator earth wire because as forest points out its clear that this wire was disconnected whilst the system was running on the water pipe earth. However, it also reinforces my original suspicion that the 'live' feed is externally supplied through the cable held by the bearded guy. Somewhere in that coil he holds in the same position throughout the demo is the Kapanadze secret which is so simple you'll laugh  :)
Acca
 "Beware of Energy Scams"
Is free energy too good to be true? "
"Offering free lifetime energy --  people are being taken for hundreds of dollars.
The inventor claims he has invented a revolutionary generator that makes free energy and promises, on his website, a lifetime of free electricity."
The arrogance of being thick as a brick
  "A person must have a certain amount of intelligent ignorance to get anywhere."
Charles Kettering
http://www.youtube.com/watch?v=kMAt0a5EWw0
Thanks Wesley  [/font]!!!
Acca...
