0 Members and 482 Guests are viewing this topic.
grizli
Quote from: romerouk on June 09, 2010, 06:37:21 PM
@hartiberlin
No ferrite cores inside.
The 22 turn coil is on top of the 84 turn coil.It makes a difference having this coil connected.I have tried with a 1kw heater and worked better but if I leave it on for too long I am sure it will blow it too.The wire in the heater normaly is not as bright as when connected in the circuit here.I will get some 500w bulbs too.I was talking about DC as the source to the system, diode and a capacitor connected to the MT output. I am not sure but I think it is arround 2kv.
I am scared to connect any scope probes as I am not sure what I am dealing with right now.
Can you please draw circuit ?
aether22
Hi Romerouk, I will join in and ask if you can clarify the circuit diagram you are using, is it the one attached or does it differ?
thx
I think the best is that he makes his own new organized thread with all the needed data to replicate.
hartiberlin
Quote from: aether22 on June 10, 2010, 07:34:53 PM
thx
No it is not.
Leave the 2nd M.O.T out then you have it.
Just go back a few pages.
bolt
Quote from: broli on June 10, 2010, 07:03:14 PM
Oh I didn't think of that I stand corrected.
Then the question is....is it cheaper to use a core that can handle the power and frequency or is it cheaper to get an high voltage FWBR, an inverter and a car battery.
Have to ask yourself is it REALLY required to loop or just get a power saving. Looping comes at a cost. First much work to do to reduce the MOT current and spark plug burnouts. I already posted solutions to get this running sweet. THEN i personally would not go the inverter route to loop round to battery and MOT as one tiny mistake is expensive inverter right off. I will add caps get this KAPAGEN to run smooth as possible low power even 1 KW at 50Hz'sh is more then enough to Drive Rotoverter to 3Kw in pure reasonce.
Imagine RV as a HV HF opto isolator circuit to dead smooth 240 volts 50hz AC pure sine. There is NOTHING else that can do this for under 200 bucks and i would have no hesitation running computers and TV's off this setup.
This setup completely removes any chance of power spikes coming thru to end user and blowing up your 42" plasma screen:)
