0 Members and 54 Guests are viewing this topic.
jbignes5
Quote from: Zeitmaschine on November 02, 2013, 06:45:50 PM
But loss-less is not magnifying. At least in my understanding.
Actually, what happens if there are two (or more) receivers? If the load connected to one receiver consumes all the energy coming from that one transmitter, then what's left for all the other receivers? What if the load on one receiver creates a short circuit? Will it blow the fuse on the transmitter through thin air?
Transmitting energy loss-less through the air is a very strange thing when examined closely.
The capacitors disruptive discharge is the magnifier.
Well lets look at resistive losses when high voltages are used... Literally no losses are seen. Resistive elements are cool to the touch in fact maybe even cooler. There are many many experiments that show this already on this forum. Current, real current is what a resistor operates on. If the source is currentless then what losses can be seen? None really.
Now to take this a step further on your question of what happens in the reciever. Well is an electric field focused or wideband? Well it is everywhere around the high voltage source. And that is my point. The receiver then is a receiver of a signal a cycle in fact only. This gives the receiver a signal to be magnified through the capacitor to run the ground pump which pulls energy from the ground into the receiver to be used at the load. In fact I believe Tesla figured out that you didn't need any distance to get this to happen.
And this is where Akula's experiments come in. The transmitter is only a source of oscillation that can be magnified through capacitance and used to pump current from the ground via the disruptive discharge of that capacitor. Simple right?
Tesla was just starting to play with these concepts and we were the ones to further it's implementation.
Unfortunately outside people like Morgan and many many others already invested huge amounts in AC and petrolium interests. They wanted their due interest on those investments and used anything to get just that. This set the human race on hold to future advances till we realized the deception and started to understand that nature does not run off of those energies. Now it is time for us to advance as a race and shake off the chaff. Get rid of what binds us to this loop and go forward.
Zeitmaschine
Quote from: jbignes5 on November 02, 2013, 07:19:39 PM
Then let us put this into a small tin can and let it happen. (For God's sake!)
It would be very nice if we could do this on this page. No objections at all.
Actually it would be an interesting experience to observe what happens when a few billion people realize that they were betrayed for at least one century. :( :D
stivep
http://youtu.be/SS_CsCX2SHc
Wesley&John:About Akula,LithuaniaExperiment,Rossi
I hope you will find it  educating and interesting as well.
There is some addition to understanding How Akula works plus new light on the general subject.And for some of you , who  is looking for easy free food - sorry if you do not  read watch and learn - you last in the row of potential benefitsiants  . ( beneficiaries) .
Wesley
stupify12
The full schematic of the Tesla Magnifying Transmitter is on the Rare Notes Figure 5. When Tesla talked about Primary he means it is a Bifilar Tesla Pancake. Look at the other figures you will see that Tesla drawed the Picture of Primary with single Coil of the Primary as for simplicity on the Figure/Illustration.
The complete and full schematic of the Tesla System is on the Colorado Spring Notes. Everything is in there the Last Large Illustration of Schematic. ;D ;D
Btw The Tesla Magnifying Transmitter and Receiver are identical and all are the same. The only difference is the winding direction of the coils that the direction of the Hv Arcs on the Transmitter is attractive to the Receiver. The other difference is how Tesla put the Capacitor on the Primary Transmitter and Receiver.
Meow ;D ;D
Lets spread the word about the Impulse Discharge of Dr. Nikola Tesla. The points you made on your post are all correct. I may add point about the wireless transmission don't forget Tesla used the Streamers/HV Arcs of the Dome to connect the other dome of the Receiver. The arcs/Hv sparks acts like a switch and a wireless connection between the receiver and transmitter. Tesla used the Ground/Earth as a conductor and also a part of the Resonance Circuit.
d3x0r
Quote from: baroutologos on November 02, 2013, 10:53:14 AM
I look with interest akula's schematics and coils and stuff, but still cannot understand the basic principle.
Phase locked Tesla coil to biffilar? Run the Tesla coil at biffilar's 1/4 self resonance or 1/2? Resonance in resonance between a shorted biffilar and another biffilar?
Anyone making sense?
it's actually 3x... or 1/3 depending on looking at time or pertime...
the drive side in the latest videos is a black heavy cable on a white bifilar with a removable length of coil at the bottom;  These coils are probably the feedback to the phase lock loop module.
The original frequency of the first coil was 50Khz something.  And 3x that is 150Khz, which is.  So the difference between the first signal demonstrated that was tall, and the second that was short and faster is 3:1 waves.  Every low in the higher power resonant signal had a high in it and every high had a low with one and a half wave between... (something)   (which is wesley translation #6 )
So the tesla coil is resonant at 123Khz, slightly lower frequency than 3x the driving coil's base resonance... so the driving side is being back stimulated by a 1/3 wave harmonic in it's second resonant point...   Approacing the coil increases capacitive coupling between the open coil and well you; a grounding rod or similar could be brought close... (I recently got a van de graff generator; and ya, large elctrostatic coupling with the environtment.  In dim situations where the voltage is near breaking out to the air; and in bad joints before improving the insulation, overflow breakouts happen on that generator; with a ground near by a spark gap is created which limits the potential of that topload... but ya, oh if I replace the ground side electrode with a point source (a probe from a meter), the tip of it almost always has a glow anywhere with only part of a turn of the crank on the generator... the draw from a point source (hairs on your head/arm) will easily satisfy the electrostatic requirement of a open coil.... but it's much too dim to film digitally, and has to be a dark room to even remotely see it...) So anyway, approaching the drive side being back driven increases its capacity and reduces it's frequency slightly from the 150Khz to nearer to the 123Khz...
All of the schematics are given with disclaimer that the turns were what was calculated, but reality was not the same, and plus or minus a few turns and pico farads helps.
But consider a scope probe is maybe a 1nf capacitor, which means when testing for resonance, that that capacitance is what's being driven, and if you are observing it, the frequency will be different than without.  Even using a near inductive pickup will influence the induction characteristics and skew the product.... so you may have to include that 1nf (1pf?) in your circuit.
It seems to me that no circuit will ever be open in an atmosphere, and that without capacitance, a coil has a minimum capacitance it can approach but never be 0....
Not sure why you consider the coil shorted; is that some opposite meaning like a closed circuit is actually open?
