0 Members and 393 Guests are viewing this topic.
jbignes5
Quote from: stupify12 on November 03, 2013, 01:09:38 AM
The full schematic of the Tesla Magnifying Transmitter is on the Rare Notes Figure 5. When Tesla talked about Primary he means it is a Bifilar Tesla Pancake. Look at the other figures you will see that Tesla drawed the Picture of Primary with single Coil of the Primary as for simplicity on the Figure/Illustration.
The complete and full schematic of the Tesla System is on the Colorado Spring Notes. Everything is in there the Last Large Illustration of Schematic. ;D ;D
Btw The Tesla Magnifying Transmitter and Receiver are identical and all are the same. The only difference is the winding direction of the coils that the direction of the Hv Arcs on the Transmitter is attractive to the Receiver. The other difference is how Tesla put the Capacitor on the Primary Transmitter and Receiver.
Meow ;D ;D
Lets spread the word about the Impulse Discharge of Dr. Nikola Tesla. The points you made on your post are all correct. I may add point about the wireless transmission don't forget Tesla used the Streamers/HV Arcs of the Dome to connect the other dome of the Receiver. The arcs/Hv sparks acts like a switch and a wireless connection between the receiver and transmitter. Tesla used the Ground/Earth as a conductor and also a part of the Resonance Circuit.
We are getting the word out but now it is in the hands of the people. Weather or not they go with this information is the question atm.
One misconception about the wireless transmission also is that you need bolts or brush discharges. Nothing could be further from the truth. In fact Dr. Tesla talked about this and concluded that those events were like a leaky pipe. Any discharge except for thew spark gap was a HUGE WASTE. This is the reason he developed a coax like insulation to go around one wire applications. You could make a connection to a wave guide in that.
To make it stronger you can connect the shield via coil or capacitor to the ground to help that process. I am of the opinion that it should be ungrounded to keep the energy in. This will create a reflective wave guide that is self containing. Tesla talks about this in the patent in this link: http://www.teslauniverse.com/nikola-tesla-patents-514,167-electrical-conductor
Each section should be overlapping and you have to correctly identify the frequency then use that to design the sections length.
jbignes5
Quote from: stivep on November 02, 2013, 10:42:00 PM
http://youtu.be/SS_CsCX2SHc
Wesley&John:About Akula,LithuaniaExperiment,Rossi
I hope you will find it  educating and interesting as well.
There is some addition to understanding How Akula works plus new light on the general subject.And for some of you , who  is looking for easy free food - sorry if you do not  read watch and learn - you last in the row of potential benefitsiants  . ( beneficiaries) .
Wesley
I would like to thank you Wesley for your contributions to this subject. Translating and communicating with others about these Ideas and experiments is a huge benefit to us.
As a side note and a certain answer to the question posed on your talk with John would be this.
TK did the exact setup you guys were talking about. One central radiator with 3 receiver coils around that... It has been done and done in the same curiosity as your guys musings about the process. The video is here: http://www.youtube.com/watch?v=rcRnprPuKUg
And of course the Turkey video for investors.
I will tell you how he did it.
The central radiator is the stout copper bar. The exciting oscillator is inside the Box that he will not let anyone look at. This Oscillator is the one I showed before and is a oil filled Transformer from the lecture. The figure 3 from the link I posted before. The other coils are grounded on one end and the the free ends are used to power anything he wanted up to a certain wattage. The ground does not have to be the real ground. It can be a virtual ground if a large enough capacitor is used in that process. The capacitor takes the place of our earth. This all has been looped and only a starting battery is used to kick start the process.
This oscillator is key to most of Kapanadze's experiments. It is the hidden secret.
Acca
 Magnetic Spin Waves...
The FS Loop Antenna  proof of concept for spin-fields
within Ferrite Sleeve inductors.
http://gmweb2.net/The%20FS%20Loop.htm
http://www.am-dx.com/antennas/FSL%20Antenna%20Design%20Optimization.htm
"One of those pieces of hardware is a coil. It has a ferrite core and a trick winding on it. To look at it, it looks like a rather oddly wound inductor. When measured on a radio-frequency bridge, however, it shows some very peculiar properties. There are certain frequencies at which it is impossible to balance the r.f. bridge, and that is a direct contradiction to what any electrical engineer will tell you should happen with a coil of wire wound on a ferrite core. Now if we take this coil and we excite it with radio frequency energy at or near these critical frequencies, we find that energy goes into the coil and nothing comes out. It just disappears. As a matter of fact we had one coil about an inch in diameter and eight inches long and we poured a kilowatt into that coil for two hours from a kilowatt communications-type transmitter. The coil was in a two-inch brass tube with a plate welded on one end and a transmission line fitting on the other. We could find no radiation around the outside of that tube at all. In other words the energy went in; none came out. The information which we got from the boys topside was that we were actually making tenser energy, which is a six-dimensional radio wave, and it is a type of energy they use extensively for radio communications, transmission of power and for pushing and pulling. In fact they use it for just about everything that we can think of. We were not able to control this energy; we could just make it. We are hoping that later on we will be able to learn how to do it, but at the present time we are just not smart enough."
Wilbert B. Smith  1961...
Thanks for the translation Wesley !! Great clip...
Zeitmaschine
Quote from: jbignes5 on November 03, 2013, 07:45:48 AM
So you are suggesting in the 2004 small round metal box there is also an oil filled transformer inside? ???
Anyway wouldn't it be better to experiment with a non-polarized electrolytic capacitor (like Kapanadze's 3-phase AC capacitors) instead of polarized ones?
Electrolytic capacitors can be build smaller in size when polarized but this polarization actually is a disadvantage because charging it the wrong way will destroy the capacitor.
jbignes5
Quote from: Zeitmaschine on November 03, 2013, 08:50:25 AM
Yes I am suggesting that in the can is a oil bath with a small transformer of the likes I have shown.
Yes if you use an AC wave then you need a non polarized cap. This could also have been done in the can as well and use the same oil as a dielectric bath.
I agree that caps should not be polarized. One simple way of doing this is to use the bifilar method which includes the cap in the coils design. The main drive cap or earth loop cap should be non polarized if you use an AC signal if you do not use an earth connection but instead use a virtual ground.
The virtual ground in an example would be when Akula touches the end of the bifilar coil. The ground inductively connects through us to the bifilar coil to allow the energy to pass into the bifilar coil.
The larger coil in the video I showed is like the extra coil in Tesla's experiment. Since it will resist the emf it will squirt out laterally and go through each external coil around the huge coil in that video.
I have an inkling that in the backyard video he was only using a single phase and in the above video he is using multiple phases. The single phase can have the bifilar coil inside of the thick radiating coil. The multiple phase design must have the coils external to the radiator.
I'm trying to download the video and see if I can get a translator software to work with it. I will have to see if it will work.
