0 Members and 138 Guests are viewing this topic.
baroutologos
Thanks Romerouk for the last videos. Good job really.
Yes, there is plenty of work ahead of us in oder to make something of real value.
First of all, we need to be sure 100% of what we are seeing. Ok you are seeing :)
The input must be measured more accurately than a mere clamp-meter. Take your time.
Secondly, the incadescence bulbs give a fairly good idea of power output. But for accurate measurments a different setup must be followed.
I am off chasing a MOT. Expecting everything from you is just stupid, since you have a job, wife, household and a kid perhaps..
I make a setup and i will report as usual.
ps: To me, it seems far better the plain ac voltage approach rather the CAP-discharge ala Tesla primary circuit style. (fewer spikes, HF oscillations etc)
vrand
Quote from: romerouk on June 10, 2010, 06:55:21 AM
The capacitor is used in parallel with the load, that is the case when powering system with high voltage ac. It works ok without it but it kills the bulbs very easy. Having the capacitor connected it cancels some of the spark i get inside the bulbs.I think the solution is not high voltage ac, system is more stable and controlable using dc.That was my first attempt.I can see already more advantages using High Voltage DC.
Sometimes 'logic thinking' kills the  good results.It's been proven to me many times. Not everything works as we learned already.It is good to try even ilogical ways.
Maybe try using your 12KV Neon Sign Transformer (NST) and rectifying it to DC, to get higher Voltage DC?
Some here have suggested that higher voltage = more "extra energy" in the Kapanadze device.   :)
Regards, Mike
bolt
Quote from: vrand on June 10, 2010, 09:26:30 PM
The RV that I understand can take a 3 phase motor and run it off 1 phase electricity with Hectors special capacitor circuit.  The Kapagen output is HV & HF.  Can not see any way to cheaply & easly to fit it to the the LV & low freq. of the RV.
It would be great if it could be done.   ;)
Regards, Mike R.
O/p voltage is controlled by number of turns on fat 6 windings and can be stabilized using 250 volt 10 amp GDT. Frequency can be changed by adding AC motor run cap bank across fat winding to reduce 15Khz to 50Hz. Once parameters all in the ball park then RV + ALT will do the rest and provide pure clean and stable sine. Even single RV running on system wil use just 20 watts but will correct PF, smooth out fluctuations and surges and clean out most of the noise while other loads then added in series to ground. This is not quite as good as RV+ALT but you will see a HUGE difference.
replicator
Hello guys!
have you ever heard about FRANK WYATT PRENTICE's EARTH ENERGY ACCUMULATOR patent from 1925?
He wanted to patent a train control system but found an interesting phenomena.
Just check the drawings at the bottom of that Canadian patent office page:
http://brevets-patents.ic.gc.ca/opic-cipo/cpd/eng/patent/253765/summary.html
He told about 6 times energy come from than the input and the design is similar than the Kapa's just he isn't using coils but "antenna" to couple energy from his system. He uses very long cable parallel to the earth. The altitude over the surfice also very interesting. I planned to try this circuit but no chance.
callanan
Quote from: replicator on June 11, 2010, 03:01:27 AM
Hello guys!
Just check the drawings at the bottom of that Canadian A page:
Great stuff! I remember Prentice's system now that you mentioned it. His patent clearly shows a system that is in essence, almost identical to JLN's Kapgen. Two grounds, transformer and spark gap all in series. Great find! Thanks very much. It seems that what JLN is doing is more like Prentice then Kapanadze.
