0 Members and 1888 Guests are viewing this topic.
bolt
Quote from: callanan on June 11, 2010, 03:18:18 AM
Great stuff! I remember Prentice's system now that you mentioned it. His patent clearly shows a system that is in essence, almost identical to JLN's Kapgen. Two grounds, transformer and spark gap all in series. Great find! Thanks very much. It seems that what JLN is doing is more like Prentice then Kapanadze.
Why go off on a tangent discussing yet another system which it totally impractical unless your back yard is 2 mile long and you can put up a wire 18 inches high?  Kapandaze or even Kapagen is NOTHING like this system except both have a spark gap.
replicator
Why go off on a  discussing yet another system which it totally impractical unless your back yard is 2 mile long and you can put up a wire 18 inches high?  Kapandaze or even Kapagen is NOTHING like this system except both have a spark gap.
bolt, maybe you cannot see the similarities between the two system this is why you say OFF, it is not problem. Maybe I was off, sorry guys.
There are several ways to utilize an energy source, in different frequencies, different methods. But I dont want to debate about your aspects, I just happy about you may found the right way how to Tesla ,Moray, Kapanatze,Hendershot and others (Prentice also) got energy by that way cos I have no chance to make experiments. The theory and the source should be common, the way how we utilize and unearth the energy would be different.
forest
What if telluric currents are displacement currents ?  Then all patents involving a long wire antenna would be like electrical resonant systems with harmonics of such currents and require huge antenna surface to tap any usable energy level. Displacement currents produce very weak magnetic flux.
Second kind devices would disturb magnetosphere to produce magnetic flux and tap displacement current only as a source of electrons sucked by high positive potential.Not need of large surface area of antenna.
Just a bit of theory.. now the question :
romarouk,
are both ground taps required in your circuit? maybe one can be replaced by a small insulated metal plate ?
callanan
Quote from: bolt on June 11, 2010, 03:43:45 AM
http://www.google.com.au/search?hl=en&defl=en&q=define:conceited&sa=X&ei=ogASTK_CDcbBcZ2_hfkH&ved=0CBcQkAE
