stivep
Uni platform for Tariel Kapanadze  and Akula  and all other Chubindze............
what does it mean?
well we start to understand Tesla,
At first to say I reserve to myself nothing at all. :) I do not care :)
All credit  you may  direct to :
SR ,Tiger,Arunas  Akula TK  and so on :)
from that  group there  is only Tiger and Arunas who voluntarily contributed ......Arunas because he is like me.
Akula delivered ,because he is intelligent and he knows that there is no other  way  however he is trying to protect his invention......
I told him that go over TK application is next to impossible....... so what difference does it make if akula is wealthy with patent or without he is  rich anyhow :)
for these who are not  familiar with patent  law. :
Even if TK did not  get the patent  his art  has priority over later  failings and his patent application is  damn good done.
What is so special about  bifilar and caduceus?
-it resonates at any frequency of its  bandwith, as part of circuit,
-fields cancelation
QuoteThe magnetic field created by one winding is therefore equal
and opposite to that created by the other,
resulting in a net magnetic field of zero
(i.e., neutralizing any negative effects in the coil).
In electrical terms, this means that the self-inductance of the coil is zero.
not  exactly true :)
Now you put rod inside and play with  capacitance :)
Caduceus used in Luthuania Experiment was just sort of bifilar but of equal geometric parameters of impedance reactances.
so say caduceus = to bifilar used by akula= to Wesley's 2012 200W experiment as I was using  caduceus winded in Lithuania.
It was not about finishing it but checking phenomena I got confirmation That was all I was in need for.200W nicely ON :)
I have had spark gap as others did :)
SR have used ferrites. say bifilar on it and HV coil and pickup coil
His light bulb was an active load!!( not less and no more)
SR stated that:
Quotetill now I'm is not able to get more.
TK has had some of lightbulbs not working   but actually some sections of lightbulbs that he  was switching on sequentially
He is a master of impedance match...after switching voltage divider that was doing the trick of need for additional  active load.
QuoteAlso he used active load
Akula has used active load and he could not  have one more  or one less  light bulb.
He is brilliant young man but knowledge about that was shared long time  before by Tiger and Arunas.
So what is or might be common to all of the  inventors form the above?
1.active load
2.pump requesting  balancing dis-balance from  the ground or counterpoise ....... yes it can work without  ground but not without  counterpoise.......... while  electrons are being pumped up
3. ferite or  ferrite substitute. that at the same time is a part of HV potential  electrostatic medium at which  its presence  makes capacitive reactance needed by the pump.
That is the hart of the device.
4. Tesla who was first in it and run the car of it. over 100 years we have been used  on the big scale by" powers"
Can it be  iron .sure it can......
Can it be cooper rod inside( thick one)? I do not know...... it might..........
left hand side of schematic is your tesla coil.............. right one is your bifilar..............
where is load it is NOT 100 ohm!!
that is only for your oscilloscope to  measure something  if you will.
what to measure was shown by Akula on his videos.
There is no need for the donut!!
pickup coil is the one that is connected to light bulb and that circuit is directly responsible for  disspating part of energy  from the ground that is coming as request comes.
There is constant time delay that does not  give time for the signal to die.
Quotenie davaj impulsu zatuchat  poslie transformatora
that was  the only knowledge that TK ever told me.
DO NOT LET IMPULSE DIE/
CATCH IT RIGHT BEFORE IT START  TO DIE.
exactly what Arunas was saying
  and  not
what Akula was implementing.
however Akula exactly knows what is and what is not.
As much as I have respect to him  he needs the time to do his  things and  he needs to have  public attention  .(security and patenting....)
so another words  carrier is low frequency say 50Hz
modulating signal is  up to 2MHz+ ................ Lithuania experiment yoke!!!
Ok I'm tired for now just got back..............
Please
understand that ferrite and no-ferrite experiments have  in comon capacitive reactace of coil in presence of electrostatic field.
just try with iron rod inside
and fallow what I gave you in points in previous post
Wesley
PS. Please do not attack me as I have nothing to hide ..well something I did not tell but that is my "insurance policy"
Questions asked:                  Wesley's response
dimensions,                     - not important flexible
proportions,                     -  as in any of akula working models flexible
distances,                        - critical square root distance law experimentally adjusted or adjusted by voltage regulation
angles,                            - parallel including  inside  rod/ however if one  central Tesla is surrounded by receiving coils                proceed as John is advising in my video (angle)
orientations,                        - as above.
winding pitch & thickness,       - as Akula from his  description
turn count and direction,          - as Akula from his  description  just skip electronics that  is all
insulation,
amplitudes,                            -PVC pipe and pickup coil HV insulation wire
voltages,                                - primary of tesla 12V secondary about 25KV is ok ( Danger!!!)
currents,                                 - as frequency of generation is fixed the self-resonance of circuit must be lower than                             frequency of generator.That means Capacitive character of  coil( HV and Low current)
frequencies,                             - his first device work at 10KHz however do what I say up there in the post....
waveform shapes,                     -sinus for carrier , spark will do the rest ( draw envelope  around spark spectrum to find                       center) it works as self regulating sort of PLL. That is what TK likely used.
phases,                                    - as Akula said but in HV spark regulator you will not measure  phase but feel phase!!
material compositions,              - PVC pipe , rod thick rod of iron, ferrite or ferrite inside aluminium  tube with the slit.
fields,                                    - if you fallow John advice that  you in new territory but results might be shocking you with                                                    NMR  response uhhhhh..........etc...
SPARK GAP and voltage on SPARK GAP IS YOUR MAIN frequency regulating technique.!!!!!!!!!!!!!
Ground not needed  but  it will not work without  counterpoise.
length of wire to the counterpoise is critical.
so might be as well ( actually it is) the length of the grounding wire
some of you than might ask the question how come  akula device was shown without any ground wire
and was  working.
Yes think about  counterpoise as balance.
find that very next day  ferrite was no longer good. :)
energy must come from somewhere and be converted to any other usable form of  energy
The only free energy you can get is one that does not require to be paid for. :)
if the device is mounted in the car than car body
is your counterpoise and there is a need for small
coil with capacitor to tune  counterpoise to the device
the same way as it is done with
Ham radio 2m antenna or HF antenna
http://www.youtube.com/watch?v=BPWjzLTsjhg
minute  5:33 look at  small coil
if the device is mounted on say 72nd floor than 2x2 meters plate ( aluminium ,iron etc.) will do the  job.
That also can be piece of ferrite or iron with coil winded on it but any destruction even your body  will  de-tune device.
Another words the more mass-  geometrically (not in weight!!!!)   the better  is stability of the  device.
Simple: You need  terrain/real-estate .
If counterpoise is used  that is insulated from the real ground it would work  but it will have its own potential other than ground
and might be dangerous( in this form of device only) for the person that  is touching  ground and counterpoise at the same time.
Physical ground is absolutely different animal than counterpoise or ground acting as counterpoise
wesley:
So Akula used in
http://www.youtube.com/watch?v=3xUjJjBUdwE
coil stack of ground wire hanging from the side of his device like  it was just rolled up..
good assumption  but dead WRONG......... :)   !!!!!!!!!!!!!!!!!
that was intentional...
He can not cut the wire!!!!!!!!!!
or he could but  detuning would be than  needed.
Active load is the load ( lightbulbs) where impedance of the load is directly responsible  for energy decipation in process of sustaining  oscillation..say one lightbulb is off than device is off.
So how come Akula shows working device and than screwed another light bulb into?
Yes he did so after all other  lightbulbs have been  hot already :)
a.king21
Quote from: captainkt on November 04, 2013, 10:29:35 AM
@a.king21 What is really interesting is the bulbs in series with mot are 320 watts, watt meter in to variac reads 300w then it seems what ever  I can get out of one wire HV end of mot to run rest of circuit to earth is free with no more input.
Keith
Any chance of a circuit diagram?
BTW I never trust my meters. All my experiments are to self loop.
(Unless it's really obvious like milliwatts in and many watts out. But I haven't found that one yet.}
a.king21
Wesley:  Can you tell Akula this please:
His energy device is a business. It has to be treated as a business. If he makes 100 dollars profit per device he already has a hundred customers just from the OU crowd. Then when the OU crowd put it in their houses, their friends and family will want one. So then he has a thousand customers.
Can he cope? That's already a hundred thousand profit.
This is what Kapanadze could not understand. He thought he was God and money would appear. He is so frightened to give his secret out that he has nothing. Just  self torture.
Akula should understand that it is  a business that is all.
It is no different to selling hot dogs.
I would prefer to buy a  device that works than spend all my time making one, and so I suspect do most people.
It really is that simple.
Сергей В.
Can somebody explain me 5 simple questions:
1. Does Unipolar {monopolar} charges REPEL each other or ATTRACT on same potential and how they repel or attract twin charge ??
2. Why radio-signals from Curiosity rover comes from Mars in 15 minutes while same light signals {laser impulses} comes to earth for 3 minutes ?? How to determine correct speed of the light and radio impulses - {not using mathematical fantasies} ??
3. Can we transform metals in isolators and vice-versa using only electromagnetic fileds and what we need for it ??
4. At super conductivity temperatures magnetic field around conductors at very high current densities a) exist ?? (how much in magnitude and how to calciulate) ??  b) is same as on normal ambient temperature under same current density and conductor diameter c) not exist (if no why not) ??
5. Does magnetic filed around conductor in which run constant current depend from specific resistance of conductor or not ?? If not why ??
Сергей В.
Blind Alleys question: One of most importanat question which i was asked the man which i know whole my life and know him the best i can. Question is simple but am not sure for simple answer.
Does there {in civilization of entities calling yourself humans} exist any normal good sense giving correct schemtic of Free Energy Device or not ?? If Yes why if No Why Not ??
I am aiming not only on Free Energy devices but much wider on very valuable things having direct conections with processes of Life on this planet ?? Kids have desire to have own personal nuke bombs ? Give them the box with RED BUTTON or not ?? What is correct and why is something correct ?? Who said something is correct or not correct ?? Maybe CNN or Foxnew ?? Or maybe Shnoble Prize winners ?? Does in fact human beings can answer on such questions or not and why {using own minds not radio controlled black boxes with big hornes }?? What if this planet is only one giant maze with Blind Alleys ?? Why silver dollar coin have two side faces and both sides are false ??
Maybe is best way for you to ignore these kind of questions ? But maybe not ??
