0 Members and 124 Guests are viewing this topic.
woopy
Woahouuu !  Ossie
very nice set up
In the black box is it a variac ?
And do you intend to ground it to your house ground ?
very motivating
many thanks for sharing
Laurent
baroutologos
Finally i have to buy a cheap Micro-oven to dismember it so as to conduct experiments! :D
I would advice anyone here before starting to open the champagne bottle, to have a thorough investigation IF we are experiencing real OU or we estimate so.
As you can see by Naudin's site with his bulbs experiment (even hough Naudin talks NO about any OU yet- only implies) the bulbs are flickering and not fully bright.
The "not fully bright - but bright" approach is a quite tricky situation for the unexperienced and can easily lead to false conclusions.
i have make a draft setup of two light bulbs 75watts of nominal power being connected to 230v mains and video them. A first video shows one lamp alone working at 67watts and a second video shows both lamps working at 44watts.
Clearly in the second case each lamps works at 1/3 of the first case. Easily by mistaking brightness estimation and power usage anyone could be lead to think wrong
http://www.youtube.com/user/baroutologos#p/a/u/1/Ld8XxrpXOMQ
http://www.youtube.com/user/baroutologos#p/a/u/0/Pi6NRmxMs8w
I try to play Devil's advocate here, so as to be 100% sure than our experimenters have produced something real and not BS-ing each other.
By no means I meant to discourage anyone and being charged for MIB agent :D
scorpio
callanan
Quote from: forest on June 11, 2010, 05:59:45 AM
it's just awesome !  :o did you started it ?
Still working on it. Lot's more to do and try....
callanan
Quote from: woopy on June 11, 2010, 06:04:48 AM
Not as good as a variac although much smaller. It's a 1200W AC power controller or lamp dimmer. Not very clean or linear on a transformer but at least gives some means of power control. Some is better then none...
http://www.jaycar.com.au/productView.asp?ID=AA0346&keywords=controller&form=KEYWORD
I am using two seperate grounds spikes and not the house ground.
