0 Members and 133 Guests are viewing this topic.
jbignes5
 Ok lets get one thing straight. Is a water fall free energy? Is any natural movement free energy or OU. NO... But from our point of view it is and that is the most important distinction. It is already there flowing. If we choose to intercept the energy flow then we are changing a tiny percentage of that flow. It does have a consequence though. Even though it is very small...
What I think Tesla was trying to do is take already established flows and use them to generate energy then send that energy where ever it was needed in the most efficient way possible. And that is the point.
You see they are not charging you per say for the energy. It is the cost of generation/transportation of that energy. Unfortunately Tesla made the mistake of giving them the means to do such. When Tesla figured this out he tried to trick them back and got caught in the process.
Niagra falls was a blessing from god. It was paid already and needed a way to be transmitted for free in the air so everyone could benefit. They did not want this because they OWNED the tap.. As if one could own the water or gravity.. Chaaaa..
But there are other flows we can take advantage of that are not so in your face like the falls was... Everey where around this planet a strange force goes into the central point of our rock we call home. This inward flow is the reason for gravity. And it is only an "in your face" physical evidence. But it is a result of another flow. If the earth in the center is at -300kv and the ionosphere is at +300kv, then we are assured that this flow is present and real. The surface of the earth is at 0V and is the balance point. 0v is not the extent of the whole system just a point of reference in a much larger system.
If we understand this concept then we should be able to design a range of points that we can turn on and off. To pulse and draw from that established range. We don't need to pump it. It is already pressurized and flowing as I write this.
Tesla went through all the directions and finally realized that we could harness this flow without one bit of input on our side. Except for the blocking oscillator.
Might I suggest that some have also come to this conclusion and the devices have been designed to take advantage of this flow. Well partially...
When Tesla first noticed that there was a voltage difference the higher you went from ground level he knew that he could harness this. It was already there for him and is for us to do so. We just need to have efficient devices to do this. This was his aim all along. He was thinking to big in the transmission of the energy he could generate from this flow. Individualizing the tap is the only real way to do this without anyone being able to mess that up. Making energy generation personal and not from someone else controlling it.
We need to start looking down this avenue. Really sit down and start hammering this out and do the work.
a.king21
http://www.youtube.com/watch?v=Nyop7rVw3FI
Akula (Roman Karnoukhow)  explains Wesley's 200 watt Kapanadze device. He reckons it would not have lasted long.
Translation anyone???
a.king21
http://www.youtube.com/watch?v=_UJXxwjqeAo
Akula explains Kapanadze's  3 phase device.
Translation Pleeeeeeeeeaaaaassssseeee!!! (please)
forest
fish cannot feel water pressure that's the correct answer....Pressure is potential energy. Tesla has given whole chapter of his famous article on this topic. It can't be electric field around Earth because it changes with elevation. Think more...
Muromets
Quote from: a.king21 on November 05, 2013, 11:59:02 PM
Hi! Translation for 200 Wt... "All that we see on the outside - a fake devices. Present only the Melnichenko transformer (Tesla) inside the box..."
