0 Members and 42 Guests are viewing this topic.
Zeitmaschine
Wikipedia: »A Faraday cage is best understood as an approximation to an ideal hollow conductor. Externally or internally applied electromagnetic fields produce forces on the charge carriers (usually electrons) within the conductor; the charges are redistributed accordingly (that is, electric currents are generated). Once the charges have rearranged so as to cancel the applied field inside, the currents stop.«
»If the cage is grounded, the excess charges will go to the ground instead of the outer face, so the inner face and the inner charge will cancel each other out and the rest of the cage will retain a neutral charge.«
What is the meaning of this?
In a (completely closed) Faraday cage there is no electric field. The Earth's electric field surrounds that cage but it isn't inside that cage. The cage is empty.
1) Now we open that cage (by removing its walls).
2) The Earth's electric field can now flow into the space of that former cage.
3) We close that cage so again there is no electric field inside.
Question: Where did the electric field go that was in the space of that cage while the cage was open?
Answer: It was converted into an electric current (going to the ground) when the cage was closed.
Therefore, if we have a Faraday cage and we open and close it in rapid succession (high frequency) then we should be able to generate a continuous ground current of noticeable magnitude. So -as I see this- simply closing and opening a Faraday cage will convert the electric field (of the Earth) to an electric current which can be used to drive a load.
Thus the next question: How to open and close a Faraday cage automatically without using a lot of energy in order to do this?
Hmmm ....
anandml
@Zeitmaschine OK fine. I have one doubt whether your assumption may applicable in Tk's Aquarium device because it is totally insulated....
captainkt
@Zeit, I think you should look at the inside of a capacitor as inside of faraday cage more like Don Smith Idea. High frequency-capacitor-Earth. To me that would make more sense as most devices do not seem to use a faraday cage as far as I can see.
Keith
Zeitmaschine
Suggestion to electrically disable a Faraday Cage
»You can't disable a cage, but you might be able to make a switchable "leak" in the cage.
You might need to do some fancy shielding around the hole and switch, to prevent leakage when the switch is off.«
Hmmm ....
Is that shielding around the hole fancy enough?
jbignes5
Quote from: Zeitmaschine on November 06, 2013, 05:22:26 AM
Yes, it is pressurized, but we need an unpressurized room to let the pressure flow in. And we have to assure that this unpressurized room stays unpressurized. Hence the idea with that pumping is to constantly pump out the room (by consuming the energy in it) so the flow from the outside keeps coming in.
Can I build my own device after watching this (instructable) video, or is this just another small talk to keep people busy? ::)
Thinking more ... What does it matter if the electric field around the Earth changes with elevation?
If it is not the electric field, what field is it then? :(
The magnetic field? The gravitational field? Or the mysterious Aether?
The unpresurized room is inside the ground. This is the sink. All we are doing is injecting a conduit into the lack of pressure or vacuum of the earth and using that form of negative pressure to pull in the field around the earth.
300kv Ionosphere
------------------------ (Pressure)
-------------  0 v surface (balanced)
.-----    -300kv core   (Vacuum)
What goes in the Earth is distributed evenly across the Vacuum and converted to a magnetic field+heat by the core ferrite crystal. This crystal grows like Ice does. It expands exactly the same. This crystal is made much like diamonds are made through enormous heat and pressure. Except in this case carbon is not the composition of this crystal it is molten Iron. The patterns we see on the surface of our earth of lay lines is guided by the formation of this crystal and is locked onto the suns magnetic influence via the poles. Since there is a viscous fluid of molten material between the core crystal and mantle there is some slippage and this continues the heat generation as well. The expansion of the heated material creates a pressure of it's own and this is volcanic activity we see.
Now to get back to the point I was making. The out flow of magnetic field is caused by the electric field that this mass creates when exposed to the vast electric field of the sun. Both inside and outside because nature always seeks a balance. The balance point is the surface due to static laws and the inside is negative and the outside is positive because of this Yin and Yang type of mechanism. The positive aspect is reinforced by the sun's output of positive electric field. It is the very same process we see here on earth but very much bigger in scope. The Solar wind is telling of the flow that is created. But that in your face proof as another inward direction. We see it as gravity but that is just the effect we see and not the total makeup of the flow structure. There are many aspects to the flow. Take all radiation that is emitted by the sun and it should neatly equal the negative potential inside of the sun. And as we have a graduating field going out of our planet so does the sun and so does every large body in our solar system, just varying in strength the further you go from the sun.
When you have an open capacitor what happens when you increase the space between the plates?
The potential(voltage) difference increases right? Hmmm...
Here is an interesting question. How much does the Earth weigh? From space it weighs NOTHING. Weight is a matter of perspective and so is a potential difference.
Now you are asking yourself what does this all have to do with these types of devices.... Well if we do not understand the system we live in then how can we design a way to take advantage of that system. This is the fundamental problem we have. We focus too much and too closely to the system we live in to see that energy could be harvested from the larger system and used any way we choose through the mechanism Tesla designed in the transmission of energy. I now understand this better. Do you? I now realize that he was right in designing a transmission system of the scope he thought about. All of his energy was trying to take an already established flow and harnessing it to enable us to live without toil. In Tesla's case and perspective he was dealing with Niagra Falls. From our point of view a better system would be to deal with the EARTH and the flow I just detailed. If we increase the flow into our planet then we would see vast changes in our environment. It would strengthen the magnetic field through that process as well and this would increase our protection from the radiation of space and the sun. Major storms would stop and our planet would become livable again. Plus we would be able to get huge amounts of energy from this method as well.
All of this other crap is just that. CRAP. They hold back valuable information to try to extort money from us. Why? TK is one of the worst offenders. Although Akula is more forth coming I don't think he is being honest with us.
The inverter-battery loop is a way to get apparent power but it is doing this in a very active method. Creating a higher voltage field has it's issues if it is based on AC or RF technology. The agitation on our cells can be very harmful and especially at 50-60 hz. The emf field at that level is affecting our mentality and most people will break mentally in High emf situations. Impulse Technology has no such affect on us if it is above 2k cycles. In fact Tesla reported great effects on the human including a feeling of well being, healing properties, spontaneous light production, hot and cool breezes and most importantly an increase in the focusing ability of the mind. This is because it is an energizing field. It does not have a forced back and forth agitation. The avramenko plug is a way to tap this field for work in our systems that we currently have. It allows a circular flow to develop and a DC like current is created from that loop. This energy is seen in one wire applications and has been experimented with for quite some time. We have the means to do this. Others have already done the work but since they are holding us hostage we have to do this on our own.
This is my last plea. I will be absent for quite some time till I can put this all together and experiment with it. I suggest that you do the same.
Take care and Adue'
