0 Members and 311 Guests are viewing this topic.
d3x0r
Quote from: zcsaba77 on November 07, 2013, 06:57:40 AM
Hi All
http://www.youtube.com/watch?v=I4eKQXYmNsk
Someone have a picture (circuit diagram) what showing in video? Thanks
regards zcsaba77
it's posted in the akula rehash thread
Zeitmaschine
Quote from: a.king21 on November 06, 2013, 11:22:20 PM
http://www.youtube.com/watch?v=DYwTVN4orqw&feature=related
Here's a transcript.  Error corrections welcome.
Since this is about magnetic fields (like the device on page 1298) I guess it taps the Earth's magnetic field (therefore it keeps running in a microwave oven = Faraday cage). Hence we should not confuse the magnetic field with the electric field.
Quote from: a.king21 on November 07, 2013, 04:46:48 AM
Zeit:  Your theory is brilliant. You could have a cylindrical Faraday cage with an opening door on the length of the cylinder. When spun, the door would open and close once per revolution.
A cylindrical Faraday cage like a (3-phase) AC capacitor in a metal housing? What if the housing of such a capacitor is short-circuited with one of the capacitor's connectors (acting as an antenna) in high frequency mode (switching rapidly on and off the Faraday cage) while the capacitor itself is in 50Hz resonance with a coil between inverter and load? The housing of that capacitor should be completely isolated from the capacitor inside. That would surely be the case if that capacitor is rated for mains voltage and has a screw mounting. Smaller electrolytic DC capacitors may be unsuitable for such experiments.
Now we should move from brilliant theory to working theory. ;D
Waiting for the delivery of my AC mains capacitor in a metal housing ...
Acca
Here is a link to the the best video by S. Wesley..  it should be watched again and again... it has 9000 views...Thanks again W.
http://www.youtube.com/watch?v=Mn8TLBsR3r0&feature=youtu.be
Here is a clip from Tiger in Russian showing these very sharp impulse waves, attached is also below a picture..
http://www.youtube.com/watch?v=gAew2ieTn-Q
"Guys, you learn stuff here first , and then the concepts reason. All materials on this topic gathered Volkov, painted all in detail. Maybe this is not the NMR in pure form, but the fact is undeniable - these are the processes associated with nuclear reactions. How to tell the difference ? This home is impossible because of the lack of equipment. These resonances are quite a few , and there are spin resonance , there is an electronic resonance, NMR is , there is a quadrupole resonance, EPR is , there is even an acoustic NMR . All these resonances are associated with the atoms of matter. They are available as the absorption and release of energy . That's FOM unbelievers and not wanting to learn a little movie. This is a modification of experience in patent Coleman . Note - the signal is removed from the working fluid 60 mm long , 10 mm in diameter . On the oscilloscope divider 1 to 10 . The sensitivity of the cell 50 . Pay special attention . Excitation occurs from the spark . Look at the width of the pulse , the characteristic " puff " duration.
Well, if we are literate and do not believe anyone - read Bolotov in the end - the end. Now there are materials on the subject, they are hard to find , but slowly emerge ... And there are works pretty serious scientists working in reputable institutions.
I wonder one thing - who benefits from all this is not to see? But the stories about the entire Internet is clogged air , and the enthusiasm with which he discussed ... And all that is known about him ... All have seen him , groped and tried to taste ..."
by Tiger (translated from Russian) today !!! [/font] -------------------------------------------------------------------------------------------------------
To :   a.king21 here is an answer to Melnichenko riddle, a company with Russian technology in Florida keeping a very low  profile in the mfg. of  free energy generators that are in Russian clip by Melnichenko.. also below is software that they make to simulate "magnetic spin waves" that are the "KEY" to mano-crystaline ferrite cores.... It' s all been here in front of everyone all along hidden in plain sight..
http://www.chavaenergy.com/how/maggen/
https://www.google.com/patents/US7830065?pg=PA1&dq=2006/0163971&hl=en&sa=X&ei=LXF7UujZF7GvigKL1YHYBQ&ved=0CDkQ6AEwAA -----------------------------------------------------------------------------------------------------------
and now the real free energy device based on magnetic spin waves below.. Spin waves in ferrite will make free energy..   Must have pulses for (efficient 10 nano-sec) OU effects... you need a spin wave front. The core effect is due to spin waves fronts, driving the spinor in to resonance. Start with full control of pulse timing and separation for three drive coils (Akula) and just tune up one at a time.
Drive coils need to be closed -- leave them open circuit and it will still work (with dramatically lower input requirment). It's the spin pulse on potential jump that is the motive force. This is the pulse Edison engineers noticed and Tesla called the radiant pulse. By wrapping a collector wire with the drive coil the resulting spin wave front drives current down the central collector coil -- this is "like squezing water along a hose". (Ideally the potential pulse is so short that it can be contained within a percentage of the drive coil -- there will be an optimum pulse width but that probably a lot shorter then anyone is using at present.)
Static voltage bias potentials are a must !-- both electric and magnetic -- can/need-to be controlled  for tuning. (This can be used to modulate the output for ease of matching/forming to power grid frequency.)
There is an exponential relationship of static potential to output -- drive with high voltage pulses for maximum effect. Conversly you will have a hard time tuning devices with low voltage pulses.
Start with very short and powerful 30 amp impulses,   -- you will need to get lots of nice rotating fields but not so easy access to interesting high power effects.. Akula is right on as all pulses have to be in sync.. and with very high harminics, (as shown in his spectrum display).
If there is a greater acoustic (squeal) coupling of the electrons are spun into the mag field rather than forced harmonicly, even though you need the harmonics to gather that crop,  then align them in the spin, through out the spin, the spin will elongate the field and travel of the photon ? if it does happen then all in the electron's field would be grabbing each others nutron causing  chaos,  maybe that's whats needed (stripping effect).
To extract the ZPE. The power goes from a few milliwatts to more than one hundred kilowatts. These circuits must be fed to function, but at the exit of the circuits, the profits of power (COP = energy of exit/input) can be very high. The profit or COP can be 2, 10, 100, 1000 and even more.
The mechanism of extraction, is based on ferromagnetic resonance. The free electrons exchange energy with virtual electrons of the vacuum. Normally this exchange is perfectly symmetrical. Result: No the extraction of energy.
This resonance is between a few hundred MHz and some GHz. Nevertheless, the circuits function at a frequency lower than one MHz.
When the electrical current increases, that made decrease inductance, and a reduction in inductance makes amplify the current... and so on. It is the effect of avalanche. This reduction in inductance has a certain limit determined by the electronic circuit. Once the stop of the avalanche, the process is reversed. Inductance increases and that made decrease the current... and so on. This return takes less time, because there is no extraction of electric output of the vacuum during this return. Normally, because of the electric losses, the avalanche does not start again without stimulation (ex: a pulse exceeding a certain value).
Signal of the generator of impulse must be a signal square, positive, with a boarding time of 10 nanoseconds of 0 volts to + 5 volts.
If the square signal is slower than 10 nanoseconds, the extraction very quickly decreases and is cancelled completely between 50 and 100 nanoseconds.
Stray capacity, at the point of connection of the transistor (M1), inductance (L1) and the resistance of exit (R1) of a value of 100 picofarads towards the mass, completely destroyed the extraction (this capacity of 100 picofarads perhaps capacity of a probe of oscilloscope).
Parasitic inductances can also prevent the extraction, if it exceeds 10 microHenries.
It is necessary to minimize the loops, as if the circuit operates at 25 MHz.
The element of extraction is the toroidal ferrite of inductance (L1).
The number of turns: 40
The diameter of the wire: 0.3 mm or more.
The core is of form annular and square section (5 mm X 7 mm). Dia ext.: 20 mm.; Diam.  int: 10 mm; Épaisseur: 7 mm.
The sectional surface specified by ferroxcube is 0.336 cm square. (AREA = 0.336)
The course of the magnetic field is 4.36 cm (PATH = 4.36).  Effective circumference for the magnetic field.
The annular form ensures, that the magnetic field is closed again. Very important (GAP = 0).
The magnetic permeability of ferrite 3E5 is 8000.
The electrical current in the reel must be 15 to 20 my minimum to be close to magnetic saturation.
It is the nonlinearity which makes it possible to extract from the free energy.
Very important: The circuit must be built like a circuit of 25 MHz. (ferromagnetic resonance is between 20 MHz and 10 GHz)
Transistor DNMOS FET must be IRF510.
Other ferrites have few chances to function.
FERROXCUBE TX20/10/7 with magnetic permeability of 3E5.
http://www.ferroxcube.com/prod/assets/tx20107.pdf
Spin wave lab software..
http://chavascience.com/wp-content/uploads/2012/07/Spin-SpinLab-and-the-S-spin-method-first-introduction-2012.pdf
http://www.chavaenergy.com/how/our-energy-solutions/[/font]
verpies
The indications of the ammeter cannot be trusted the way it is connected.
It would be more credible with a huge capacitor connected after the ammeter.
When will these people understand that: average Amps * average Volts <> average Watts  ?
Also, as usual, the brightness of the bulbs is not quantified and not related to Watts in any meaningful manner.
@Grumage
How much does one of those Wattboxes cost you?
a.king21
Quote from: verpies on November 07, 2013, 07:53:28 AM
Well, it seems easy enough to test.
