0 Members and 41 Guests are viewing this topic.
stivep
Quote from: Hoppy on November 09, 2013, 05:18:33 PM
Exactly!
Thanks Wesley for the video translations. I agree with Akula that the coils are primarily eye candy but that's really not a revelation, as many of us had already come to that conclusion. The big question for me is as its so obvious to Akula and some of us on this forum, why was this pile of crap tolerated by the 'expert' Turks, or are we to assume they tolerated it because they were 'in with it' and party to the deception.
I would ask Wesley one question about his witnessing the Kapanadze garage video demo. How convinced are you that the earth braid did not contain a hidden wire? Did you very closely examine the full length of the earth braid and in particular the far end termination? Remember that a.king21 told us that his inspection team was not allowed to disconnect the Aqua2 earth braid for inspection. I assume that you were not allowed to do the same, so how can you be absolutely sure that the most obvious method of faking was not implemented?? I have already shown how easy it is to power a 2KW electric fire from a very thin conductor with heat resistant teflon sheathing hidden inside a braided earth tube. It would be even simpler to hide a conductor that only needed to power a couple of lamps!
You come across as a very trusting fellow Wesley but have you given them too much benefit of your doubt?
not only no doubt but also video prove of it.
http://www.youtube.com/watch?v=fBgDwG2ZLkM
start from minute 12:50
Wesley
a.king21
Exactly!
OH COME OFF IT!!!!
I told the forum SEVERAL TIMES that the EARTH BRADID WAS DISCONNECTED BY THE TEAM!!!!!!!!!!!!!!!!!!!!!!!!
Which part of DISCONNECTED do you not understand.
Forest:  At high frequencies and high voltage Tesla's one wire system allows single wire electricity. In that case the earth acts like a standing wave reflection, and puts that part of the circuit into auto resonance. This was first discovered by Oliver Lodge  who found that a long wire contained nodes. By paralleling a spark gap along 2 long wires he found that a second spark gap arose at the nodes which was stronger than the original. So you had 2 spark gaps. I've done the experiment. I have not measured it for extra energy.
Hoppy:
My opinion is that the earth is required to put the device into auto resonance and removing it eventually causes a phase shift and the device loses power. This can be replaced with the negative of a car battery.
Wesley uses the term counterpoise.
Lodge found that a long wire contained nodes and  Tesla showed a system where he couuld light lighbulbs on a single wire by using these nodes. Bedini in his videos also talks and demonstrates how to tap these nodes with a bridge rectifier.
a.king21
Zeit:
http://www.tuks.nl/pdf/Patents/Benitez/GB191417811A.pdf
Good old Benitez again
Remember : THIS IS A GRANTED PATENT. Not an application lol.
He describes the use of  capacitors to pump the ground.
He uses the term battery which in 1915 could also mean condensers or leyden jars.
I built this device which uses a mega tesla switching system but could only get a neon to light for 2 minutes
before I had to re - energize the circuit with a momentary injection of electricity.
However my device was a Heath Robinson affair as I do not have a workshop. The Tesla switches could be replaced by relays
and it would be a great project for the electrical engineers.
This video looks at part of this unsung genius's patent
https://www.youtube.com/watch?v=zwiQGxkXC9U
forest
Сергей В.
Привет всем !!  :)
I want to show you something you have never seen in your life before.  I have told you about ancient civilization of our ancestors and their cosmic level of technology.
Now look at these pictures from south Siberia precisely from Kuzbas area. It is in Kemerovo region. What you see is fantastic. Complete wall in high mountain area made like we made our houses from bricks in. But there is one small difference. Every "small" Kuzbas brick have thickness 7 m  and weight more than 2000 tons of pure Granite stone (more than 2 million kg) and whole wall has 12 levels row upon row. (Balabek block has 1000 tons). Granite wall is more than 40 meters in height and had been set up on 1020 meter top mountain above sea level. Do you know any technology which can transport and make 2000 tons bricks in high mountains ?? What is extremely interesting, scientist have found remains of melted stone under enormous temperatures 10 million degrees and more. Clear signs of stone vitrification under the strike of Ancient Cosmic weapons.  And all of this is manmade in deepest Sibirian Taiga. Maybe i need start experimenting on levitation technologies, scalar propulsion and leave this parasitic civilization forever?? Does anybody know for such levitation technology and ancient megalith tools ?? This is another one stong proof for truthfulness of Slavonic-Aryan Vedas of our Cosmic Ancestors. Think about ??
Удачи !!
Сергей В.
